SOURCE: Dell Inspiron 1526 Bluetooth
ya just purchase a bluetooth device it will come around rs120 and then install its cd and start using bluetooth device by connecting into anyone of usb port
SOURCE: how to do a master reset on a dell inspiron 1526,
Step 1: Start up your computer and as the computer logo appears (such as Dell orHP) hit "Ctrl>F11" simultaneously. This may be different fordifferent machines, but the most common keys to hit are"Ctrl>F11." If this does not work, the F8 key has been said towork for certain machines.Step 2: Select "Repair My Computer" from the list of menu options thatappear and press "Enter."
SOURCE: Dell laptop ... inspiron 6400 System/adminstrator password
I believed this can be resolve by clean the cmos battery. you need to remove the cmos batery from the laptop then power it on then immediately turn it off. then put the battery back to the laptop then power it on keep tapping on f2 to enter setup. please follow the instructions from the link to remove the cmos battery http://tinyurl.com/yb3mhyg
SOURCE: dell inspiron 1545 has authentication
The aim is to reset the BIOS so that data concerning passwords are
cleared out. This is done by moving a jumper on the motherboard.( The
biggest challenge is to find it).
Note that: This procedure also resets the BIOS settings. If
you have made changes, this manipulation will reset these features to
default.
If the jumper is on 3-connector pins, place it on the middle and the initially uncovered pins.
Wait for some time and put the jumper in its original position (PIN1-PIN2).
If the jumper is on a 2-connector pins and that it holds on a single
pin, place it on both, wait one second and then return it to its
original position.
