Whirlpool Cabrio HE 4.5 cu. ft. Ultra Capacity Plus Washer
Problem for Whirlpool Cabrio HE 4.5 cu. ft. Ultra Capacity Plus Washer
Shirt caught between the drums on my whirlpool cabrio washer
By nannieo on Apr 20, 2009
how do get between the drum and the plastic cover to get the shirt?
Best Solution
posted on May 05, 2009
Helpful)
poormickey
Rank: Apprentice
Rating: 94%, 4 votes
1. Unplug and take off the top of the washer.  There are two pressure clips in the front inside the crack between the top and body of the washer.  Use a stiff putty kniff to depress the clips and flip the top up out of the way.
2. Pry the top plastic shroud off the tub.  There are a series of plastic retainers clips around the shroud.  Pry them up and remove the shroud.
3. On the small agitator on the bottom of the washer, use your putty knife to remove the domed plastic cap in the center.  Pry it up with the corner of the knife to expose the nut.
4. Use a socket wrench to remove the center nut.  It will likely take a good deal of force to loosen it.
5. Once you have removed the center nut, get another person to help you lift the stainless steel inner tub out of the washer.  Place it aside.
6. In the bottom of the outer plastic tub, you will find the shirt (or other garment) caught in the drain.  Remove the screws on the top of the plastic drain cover, and lift up the drain cover.
7. Remove the stuck item(s).  For all the coins and small part that have fallen into the drain tub, you may have to open up the back of the washer and remove the drain hose to access the items in the drain.  Luckily the drain hose is held on with cheap hose pressure clamps, so you can do this relatively easily.
8. Call or email whirlpool and tell them that the washer is pulling clothes into the space between the inner and outer drums.  They will respond by telling you they have never heard of this problem before and if you need service, call "A&E Factory Service toll-free at (800) 771-3029."
9. Be frustrated and vow never to buy a Whirlpool product again.
Hope this helps
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Whirlpool Cabrio HE 4.5 cu.
Questions and Unsolved Problems for Whirlpool Cabrio HE 4.5 cu.
Do you recommend Whirlpool Cabrio HE 4.5 cu. ft. Ultra Capacity Plus Washer?
Answer
Answer
I am getting an error code of 5d or SD. It sounds like it's trying to drain but does nothing. Does... (More)
Answer
my Whirlpool Cabrio washing machine power button sometimes won't turn on forever... I press it over... (More)
Answer
Once it starts to agitate it acts and sounds like its continuously starting and it has a clicking... (More)
Answer
I checked the drain hose and the water hoses running in to the machine and there wasn't any leaks... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Cabrio HE 4.5 cu....:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14882
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
