Quit working, unable to turn on unit
My rca drc282 dvd player is not working. I already tried unplugging it and plugging it back in. Worked fine for a month, what's up? I tried turning it on at the unit and with remote.
Replace caps in power supply had same problem. 12volt line week reads around 9-10volts. 2 caps are 1000 at 16v and 47 at 16volts.
Posted on Oct 15, 2009
DVD Player will not power on. Indicator light flashes repeatedly.
Since the players of this kind are not repaired because of the low cost of new, just replace it.
Jul 06, 2017 | Televison & Video
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
My toshiba sdk990ku dvd player stopping playing the audio. Have connected via HDMI to LCD HD tv and worked for months! One day audio stopped, but picture is fine. Tried different HDMI cables, dvds with no...
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Nov 18, 2010 | Toshiba SDK990 Player
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
RCA DRC8030N No output
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Nov 09, 2008 | RCA DRC8030N
Help with dvd player DRC282 remote code
I purchased this same DVD player (DRC282) and none of my universal remotes worked for it. Since I was lucky enough to buy one without a remote, I ended up purchasing an RCA universal remote (RCR3273). Once again, none of the codes worked so I had to unplug the unit for 5 minutes, then plug it back in and hold the Standby button for 15 seconds to return it to it's factory settings. I manually searched through 71 codes before I found a match but the play, pause, rewind and many other functions failed. I tried again skipping over 71 and found the right code at 115 tries. That one had all the functionality I needed. You should try the same strategy with your Comcast universal remote. Skip the first match and keep going until you hit the second manual match.
Apr 09, 2008 | Televison & Video
DVD Player does not work
General Problems
Player won’t work (locks up)
• Try unplugging the AC power cord and plugging it back in.
• Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button—wait at least 3 seconds
before you release both of the buttons. You’ll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the contents of the Disc Library.
Mar 15, 2008 | Televison & Video
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
