Question about GPS
Garmin Streetpilot 7500 screen goes dead
After powering up, screen comes on, after 30 - 60 seconds of use screen goes black, like not power. Can be started again and the same thing happens
  • 3 more comments
  • Anonymous Nov 04, 2007
    I have the same problem with my Map 76. I get the spalsh screen and then the screen goes almost black(about 95%) the quickly goes completly black. I am sure it is working as I can tell if I turn on the backlight.
    Any thoughts
  • Anonymous Jan 05, 2008
    When battery in my GPS low and I plug in just
    car charger, screen go blank
  • marczak Jun 21, 2008
    I have the same problem- One day it worked then the next day I turned it on- stayed on for about 30 seconds then turned off and I got a black screen. I tried with out the plug and with the plug into the car lighter.
    We have only had it since 11/07. Any help??
  • m_ti_m Aug 08, 2008
    when i put in battry my palm turns on and the screen flikers ACCESS POWERED. then it keeps flickering on and off saying the same stuff.. please help??
  • Anonymous Feb 01, 2009
    Same problem with my 7500. Garmin needs to address this defect or replace all of these defective units.
I am having a similar problem with my etrex summit hc. after i cycle through the main pages it will automatically turn off right after the satalite page
Posted on Aug 18, 2008
I have a similar problem with a 7200 which has starting shutting off on its own. First I discovered that if I turned the GPS receiver off (like I was using it indoors) it stayed on. After some more experimenting, it seems that if I just disable the WAAS/EGNOS function it also stays on. This reduces accuracy, but may be an acceptable work-around (certainly cheaper than several hundred $ repair bill).
Posted on Dec 11, 2007
If its just the 12 V adapter - how about using a power inverter (around $30.00) to power the device?  A little cumbersome, but a whole lot less expensive.
Posted on Oct 29, 2007
I have a garmin street piot 7500 and it shuts off by itself when suing the 12 v adapter in the car only.they sent a new power cord but it didn't solve the problem.It works perfectly in the house with the ac adapter and also with the 12v cord attatched to an indoor wall outlet adapter,any ideas?I refuse to pay garmin $400 to repair a defect .I have seen similar problems on other sites with this model and others .thanks...rich
Posted on Oct 22, 2007
Tequiza,
I am having the same problem with my 7500. Do you have your power supply ALWAYS powered on, even though you may have your unit off? Do you have the same problem with the AC adapter? It may be just the 12V DC adapter. Bad news if it's out of warranty, Garmin wants $400 to repair. That's outragous IMHO.
BasicWiz
Posted on Oct 15, 2007
I am having the sauess is that me problem with my 7500. My guess is that a power component is heating up and shutting it down.
Posted on Oct 13, 2007
How can I get this product fixed?
Garmin GPS is kind of a computer WiFi. You should ask at a computer store for someone who repairs wifi devvices
Apr 28, 2015 | Garmin StreetPilot 7500 Auto GPS GPS...
Where can i find a replacement screen for my garmin streetpilot 7500
http://www.ebay.ca/sch/i.html?_nkw=garmin+streetpilot+7500+LCD&_sacat=0&_odkw=garmin+streetpilot+7500+SCREEN&_osacat=0&_from=R40
Jan 10, 2013 | GPS
GPS StreetPilot c340 quit working
Plug charger in, and then reset it. Let it charge for awhile before tryng to use it though. It sounds like the battery is very very low. When it is plugged in it still will not operate unless the battery has some charge in it. I hope this helps.
Apr 18, 2009 | Garmin StreetPilot c340 GPS Receiver
Frozen Screen
I had this problem and the only way to solve a frozen screen is to let the unit run out of battery and bring it back to life. Battery will die out on you for 6~8 hours. Once battery is dead you must do the following.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Black Screen to no power
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My Garmin c550 will not come on anymore. The screeen is black
Check the 12v power cord to make sure its still powering/charging the unit. Usually they have a light on them that will show if its receiving power or not. You can also unscrew the tip of those things (on most cables) and check the fuse to see if its blown. If its not lighting up and the fuse on the cable is ok check the one in your truck to see if it needs replacing.
If the cable is not the issue then the GPS is probably dead. If its not under warranty the flat rate repair fee from Garmin is $200
http://www8.garmin.com/support/outofwarranty.html
Jan 18, 2009 | Garmin StreetPilot c550 GPS Receiver
Street Pilot start up problem
MIne did this mornig too!
What a coincidence.
I have no clue. I plug it into the power adapter and nothing. nada.
Whats up?
Sep 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin won't stay on
Oh man.. I also bought the c330 on black friday... powers on and wont get past the blue street pilot screen--just shuts off! Will "work" when connected to the PC, but who's going to drive around with a computer?
Is Garmin doing anything about this?
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c530
According to technical support, the "glitch" has been fixed with the latest web updater on the Garmin site. In the meantime, you will need to leave the unit unplugged for upto 48 hours to allow the battery die and the unit to get out of its "hang up". Once the battery is completely dead, plug the GPS into a computer (USB) and it should come back to life. Then do the update.
Hope this helps.
Nov 02, 2007 | Garmin StreetPilot c530 GPS Receiver
GPS Logo
435 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
