On a 375 h s#201202020049 change the element in the compressor crank and run for 10 minutes good are and then shuts off and it won't crank back turns over but won't start
Suspect either bad solder connections somewhere or a issue in the power supply of the set----set will shut down for a number of reasons--it monitors voltages inside and if some go high or low it will shut down.
DO NOT ATTEMPT ANY REPAIRS, CALL THE FACTORY PHONE NUMBER IN THE OWNERS MANUAL AND FIND OUT WHERE TO HAVE THE TV SERVICED, IF YOU ATTEMPT ANY REPAIRS THEY WILL VOID THE FACTORY WARRANTY. THIS IS CAUSED BY AN ELECTRICAL FAULT INSIDE THE TV, IT SHUTS DOWN AS A SAFETY FEATURE TO AVOID ANY FURTHER DAMAGE.
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
You have to do a relearn procedure on the anti-theft system:
Attempt to start the vehicle. Leave the ignition on until the THEFT SYSTEM indicator turns off (about 10 minutes). Turn the ignition switch off. Leave the ignition switch off with key in for about 10 minutes. Attempt to start vehicle.
Power Light Shuts Off
If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Power Light Flashes
If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
the only method that work was pulling the fuel pump fuse,wait 1 minute, crank her with out your foot being on the gas
for 15 sec. Put the fuse back in , and start her up normaly. 1 st
attempt she started but cut off, redid the process over , got in
started her up normally, but had my foot 1/4 way down on the
acclerator. She started and feathered the gas til she was fully
operational. Let her stay on for about 10 minutes then took her out for
a good long spirited drive.
