Question about Stanley Air Tools & Compressors
Bostitch n80 framer blow by by trigger asemably
    President:
  • Stanley Master
  • 1,388 Answers
Your nailer incorporates the (tva6) trigger valve. It is available online at www.bostitch.com, cost is about $20. To examine the valve, remove nails, remove retaining pin holding trigger, remove one or two pins holding tva6 valve (the pins holding the valve are in the body/handle just above the trigger. use punch that fits snuggly in a 3mm hole). Mark the valve in relation to the body of the gun. After several pins are removed apply air pressure to pop-out the valve. Use caution because the valve can came out with force. Reduce air pressure and use heavy glove to catch the valve. With tva6 valve in hand, notice notches on side of valve for roll pins. Remove two more pins to expose the inner valve. The middle seal of the inner valve is usually the problem, it could be cracked or fits too loose. You could try replacing the seal with a tight fitting oring. May work. or just replace the valve. Good luck with your repair.
Posted on Apr 20, 2009
How do i rebuild my bostitch n80 frameing nailer
Bostitch nailers are simple to rebuild. Bostitch company was sold to Dewalt so parts are now easier to obtain from local Dewalt service center. Use Ork11 oring kit and tva6 trigger valve. These parts are also available on ebay. Good luck or your nailing projects.
Sep 18, 2014 | Stanley Bostitch N80CB Coil Framing Nailer
I Have a N80 Coil Nailer. It was given to me without the manual. I down loaded a manual, however it is not clear how to set the nail depth. Can you advise?
Bostitch nailers used three methods to adjust how deep the nail will set. On stick nailer, there are one or two screws on the lower contact arm allows you to shift up or down. On coil nailers and others , there is thumb screw on side or under the trigger. Finally on some coil nailers, there was a series of spacers that snapped onto nose of the gun. Good luck
Nov 21, 2012 | Stanley Bostitch N80s Nailer -rebuild...
My hitach nr83a just blows air out the exhaust when pluged in and wont shoot. is this a trigger or exhaust problem ???
Your problem is most likely where the cylinder / head come together. In the Hitachi framers, the cylinder is designed to move up and down (unlike Bostitch where the head valve moves) so if the O-rings are dirty or broken, or the spring under the cylinder is broken - the cylinder won't make a good seal to the head valve.
You can try plugging the tool in and giving a couple of firm taps straight down on the head with a rubber mallet - if the leak stops or slows you'll know the problem is with the cylinder movement.
Check the head valve seal - often they get sand / debris embedded in them which prevents the cylinder from making a good seal.
It is rare for a Hitachi trigger to be a problem.
Nov 24, 2011 | Hitachi Nr83a- Strip Nailer-driver Blade...
Bostitch N80C. When I connect air to gun it leaks from cylinder cap - (exhaust ports) Piston stays forward when under pressure.\r\nPushing safety and/or pulling trigger have no effect on problem. Tool is...
Most likely a seal is leaking which is preventing complete reset of the tool to the firing position. Follow the instrucitons in the link below to get to a site that will provide a diagram of the gun and the parts list. I would recommend replacing all of the o-rings and a good cleaning and lube.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
May 02, 2011 | Stanley Ring Repair Kit KTBO650 for...
Nail goes in to deep,when i press the trigger
Bostitch n80 utilizes a driver with a threaded piston which may be adjusted to required penetration. Use thread lock to keep in place. If piston is not out of adjustment then lower bumper may be breaking down from heavy use and allowing piston to travel too far down cylinder. Remove head being carefull about gasket, remove driver and examine bumper for missing pieces. If it looks good check for loose piston on driver. Repair as needed. Parts are available at www.toolpartsdirect.com Good luck on your repair.
Aug 16, 2010 | Stanley Bostitch N80CB Coil Framing Nailer
Blows air out of trigger
I assume this is a Bostitch tool and if so there is a broken o ring on the trigger valve assembly that needs fixed. Go to Bostitch.com with your model number and you can buy it online. If other than Bostitch give me the model number and brand and I will try and find a breakdown.
Jan 30, 2010 | Air Tools & Compressors
My Bostitch N80 fires full auto when I hook it
I would check the safety first to make sure not stuck because this tool is a bump fire. Let me know and then I will find a kit and schematic for you or you can go to Bostitch.com and find the parts online, but I honestly think that you have a safety issue or the trigger valve is malfunctioning.
Jan 09, 2010 | Stanley Bostitch N80s Nailer -rebuild...
Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
May 23, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Blow by
If the nailer is leaking out the trigger, it has to be replaced. If it is coming out of the exhaust then it needs an overhaul kit.
Parts are as follows
Trigger valve P/N TVA 11
Overhaul Kit ORK 11
Hope this helps
Apr 20, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
648 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
