Black screen just returned home from florida took my laptop out of the box turned it on and the screen is dark it worked fine in florida
  • waynec1932 Apr 20, 2009
    i can just faintly see any thing on the screen
  • Thomas Marengi
    Thomas Marengi May 11, 2010
    Can you see any image on the screen whatsoever, albeit dark?
    Problem Solver:
  • 9 Answers
Two things. Inverter, or CCF tube. The CCF tube in a LCD is equal to a florescent lamp but is usually .05mm thick, and 103mm long and is placed (soldered in) at the base of the LCD screen. The inverted goes out more then the CCF, but it does happen.
The inverter in most notebooks are placed under the LCD like this pictured.
Just below the base of the LCD is the inverter. This is a Gateway Notebook showing the location of the Inverter to the LCD. Best thing to do in these cases is to purchase a new inverter from the company who made your notebook as a new screen can cost over $100.
Posted on Apr 20, 2009
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 08, 2011 | Computers & Internet
The screen will not come on when the computer comes on on my dell xps notebook. The laptop comes on but the screen stays black when turned on.
I had a similar problem with a one year old Dell laptop, and it turned out that the screen was OK on battery power, but when you plugged it in to the AC charger the screen went very dark. It turned out to be the LCD backlight inverter, which I purchased from a fellow in Florida for about $16 and installed by following the instructions at http://www.insidemylaptop.com/remove-replace-lcd-screen-video-cable-inverter-on-dell-laptops/ . Hope this helps you out a bit...
Mar 29, 2010 | Dell Studio XPS 16 Notebook
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
Black screen after returning from florida
plug in > if charge light comes on and screen black proceed.... if no charge light comes on on laptop your charger's not working
plug into external monitor > if the external monitor works fine with laptop then your LCD is not working, you can look for the Function key (should be bottom left) and the monitor button (probably f7) and switch back and forth... this should tell you if the lcd works or not.
Apr 20, 2009 | Gateway MX6027 PC Notebook
Phone wont turn on
replace the battery it will no longer take a charge. it has enough power in battery to turn on but not to function. a new battery will solve your problem.
Apr 18, 2009 | LG VX9800 Cellular Phone
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
