Question about Artec GUA-SL ATX Mid-Tower Case
When playing overheat and i'd like to now how to setup right the fans
I have 1 fan in front 1 on the side and 2 back. i'd like to now which one has to be the blower. and, when i'm playing on internet the video card reach almost 100 degrees, i checked the video card and i ((think) the isulation between the chip and the card is separate. Thank you guys in advance. Omar
    Genius:
  • 1,601 Answers
I would have the front and side blow in and the back ones blow out.
Posted on Oct 23, 2007
    Sergeant:
    Champion:
  • 293 Answers
What do you mean blower? they all blow air sir. anyway feel the air on t hem with our Palm to know. video card reach almost 100 degrees << This is impossible if its in Celcius this is flamming hot already.
Posted on Sep 21, 2007
SOURCE:
Can i fix the overheat problem on motherboard myself?
Yes you can. Remove the case of the computer. Vacuum out all the fluff on the heat sink and fan using a 2" paint brush and the crevice tool on your vacuum. Vacuum the grills and vents on the front, back and sides of your computer. Fans are cheap, so you may elect to just replace it. Get ball bearing fans as although they are a fraction more expensive, they last longer. Consider adding more case fans at the front and rear of the case. Don't forget to also clean the Power Supply Unit. Also your video card if it has a fan? I used to do my old P3 every summer as it would shut down on overheat.
Mar 24, 2016 | Computers & Internet
What is a fan switch
It either turns the fan ON or OFF. It may also allow the fan blade shaft to rotate at 1, 2, or 3 speeds depending on design.
Aug 01, 2014 | 1998 Dodge Grand Caravan
I have cleaned the drain holes, filter, coils, etc; however, water is building up in the front of the unit and the fan starts making a loud clattering noise. There is no water built up in the back;...
If your a/c have a housing, set the upper front side 1/2" away from the wall and the lower front side 1 1/2" away from the wall. Some units with plastic base pan should be inclined more defending on the height of the drain line fitted in each model.
Sep 02, 2011 | LG Electronic Window Air Conditioner
I have a Whirlpool gold conquest side by side model GS5SHAXNL00 that has a clicking noise coming from the rear. The freezer isn't keeping things frozen but the fridge side is nice and cold. I can hear the...
These models have two fans. One is located inside the unit. The fan inside blows air across the cooling coils. With the door open this fan is usually running other than defrost cycle. If this fan has stopped it will cause the compressor to overheat and the relay will cycle.
The second fan equally as important is located under a fiberboard cover accessible from the back of the unit at the bottom. This fan is usually noticeable by an air flow sound. Usually air flow is detectable out of the front grill. If this fan fails to operate, blocked due to a major build up of lint the compressor will overheat and cycle as you hear,
Hope this helps?
This is the fan inside the freezer.
Jun 25, 2017 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Firing Order for 85 Fiero GT 2.8L
The firing order is 1-2-3-4-5-6. The odd numbers are front to back on the left of the fan and the even ones on the right side of the fan. The distributor turns clockwise and #1 is at the 5 o'clock position. Hope this helps.
Oct 10, 2010 | 1985 Pontiac Fiero
What do the 4 realy fuses go to that are behind the right head light under the hood
i have a1994 cutlass ciera S, 3.1 motor, it has 5 relays, from the radiator side to the right fender 1) fuel pump, 2) A/C, 3)blower motor,4) fan#1, 5) fan#2, fan #1&2 refer to the radiator fans,#1 fan is the puller fan (motor side) #2 is the pusher fan,( in front of the radiator) ,hope this helps.
Oct 03, 2010 | 1994 Oldsmobile Cutlass Ciera
2002 jeep grand cherokee larado is over heating. The cooling fanonly runs if I hotwire it. I changed th thermostat. Temp gauge is reading . Could it be the cooling fan relay if so where is it located. The...
Fan relay is located under pass headlight. Remove light assembly, use 2 1/2 " hole saw to drill hole in plastic housing ,3"from back wall, 3'' from left side.This will put you right over relay. Unscrew two bolts,replace. Relay was $40.... dealer wanted$350 to remove front bumper to replace it.
Sep 02, 2010 | 2002 Jeep Grand Cherokee
I have a compaq presario f700 and it never overheated until one day i played a game on ninjakiwi.com called SAS zombie assault 2. Now when i listen to music on windows media player or watch videos on...
Insufficient information, but try this for starters:
Make sure the laptop sits on a hard surface and the fan vents are not covered/clogged.
1) Run windows only on a fully charged battery and see if it overheats
2) If not, run media player only, and look for the same
If it overheats in either step, you have a hardware/software problem.
Hardware problem could be that the fan has failed completely and needs to be replaced.
Software problem could be incorrect fan settings, although I do not think you can turn the fan OFF on a laptop.
IF the laptop overheats in Step 1, I would definitely suspect a hardware problem. In that case, run the laptop but do NOT log into windows. Go into the BIOS (check fan settings in there, if there are any).. leave it running in BIOS and see if it overheats then.
Aug 18, 2010 | Computers & Internet
Accord with 2.2 runs a little on the warm side and i noticed today only 1 of the 2 fans behind radiator seem to work would this cause engine to overheat
what is a lil warm did engine overheat light come on? 2 fans 1 likely works with a/c. if good themostat done.ASAP
Apr 24, 2010 | 1995 Honda Accord
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
Open Questions:
See all Artec GUA-SL ATX Mid-Tower Case Questions
Artec GUA-SL ATX Mid-Tower Case Logo
69 people viewed this question
Top Artec Computers & Internet Experts
Ekse
Alun Cox
Are you an Artec Computer and Internet Expert? Answer questions, earn points and help others
