Question about Kenwood eXcelon KDC-X879 CD Player
Kdc-x879 In the mornings if its chilli or cold outside my kenwood cd player flips open and immediatly powers off.. One it warms up outside I turn the ignition on and the face flips downd and if i hit power the radio works perfect all day. Next morning same problem.. Its perfect all through the summer, is it worth fixing any ideas what it may be thanks.
  • tommynbrooke Sep 22, 2007
    What would your shop charge to tatally fix my unit..
    thanks again for your help
  • Marvin-63 Feb 24, 2008
    I have the exact same problem as tommynbrooke. My faceplate no longer flips down, hot or cold, but started out as a cold-only problem.
    1) Which flex ribbon cable is the defective one, as there are 2 that route into the display panel (1 from deck & 1 to the faceplate)?
    2) Where can I buy the flex ribbon cable?
    3) Is there a "store" (on-line or not) that I can buy other custom parts for this deck (i.e. plastic gears, etc)?
    I am a handy electronic guy preparing to fix this myself!
    [email protected]
  • 752 Answers
It needs a new ribbon cable. Some car audio repair shops stock these (mine does). Part is about $20-30. Labor will depend on the shop.
Posted on Sep 22, 2007
SOURCE:
How do I get cd in cd player on KDC-X879?
Press Eject button top right to drop the front panel down, insert CD in to slot.
You can download the manual here:Manual
Jan 25, 2012 | Kenwood eXcelon KDC-X879 CD Player
My flip face sony cd player wont do anything, but still plays, sounds tooo high help
A common problem with flip face headunits is the flexible cable that connects the face to the main unit develops a hairline fracture through the cable after a while and disconnects 1 or more conductors. this can have the effect you are experiencing. try gently pressing on the cable and see if any functions return
Aug 13, 2010 | Kenwood eXcelon KDC-X879 CD Player
Faceplate flips out up down up down but only when its cold out and radio turns off and on
sounds like ;you may have a bad ribbon cable, or face position sensor lever inside the unit.
Dec 10, 2009 | Kenwood eXcelon KDC-X879 CD Player
Unit only has power for a few seconds
could be a couple of things..1. issue with your ground connection 2. ventilation
May 29, 2009 | Kenwood eXcelon KDC-X879 CD Player
How to connect ipod to the cd player
thats a special cable that you plug in to the ipod and to your radio, there is some wireless solutions but i dont recomend you re not gonna have good quality sound with it, you can fid it in best buy walmart and radio shack
May 17, 2009 | Kenwood eXcelon KDC-X879 CD Player
Yeah remove the unit from your car,
Go to car audio store and buy Kenwood receiver without the
fancy opening front.
Dec 17, 2008 | Kenwood eXcelon KDC-X879 CD Player
Code
the universal code used to be kcar but you have to have a specific type of remote to spell it out
Feb 23, 2008 | Kenwood eXcelon KDC-X879 CD Player
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact [email protected] for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
Kenwood kdc-x869
Alot, of the radios have a common problem with the connection from the radio's detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, and the display partially turning on and off.
Dec 15, 2007 | Kenwood eXcelon KDC-X879 CD Player
Kdc-x879 won't recognize cd feature
I am sorry to tell you this, but there is no easy fix after pressing the reset button. The unit is not even recognizing the cd player, so it could be one of many different problems, all of them being electronic and inside the unit.
It could be a voltage regulator that supplies the cd deck, it has 3 of them. It could be the ribbon cable that connects the cd deck to the main board, but that is more unlikely. It could even be the microprocessor.
There is just no way to be certain without putting it on a test bench and troubleshooting it with the schematic in front of you.
If you have some electronic troubleshooting skills, I can email the schematic to you. I have it in PDF format and you can check it out as long as you have a power supply, multimeter and knowledge of electronics.
Otherwise, you will need to take it in to an authorized Kenwood repair center.
I hope you found this helpful, but you do have a serious problem with the unit.
I have been repairing these type of radios since they started making them a couple of years ago and this problem has had several different fixes for this same symptom and it has never been an easy fix.
let me know if you need more help
Oct 17, 2007 | Kenwood eXcelon KDC-X879 CD Player
Kenwood eXcelon KDC-X879 CD Player Logo
158 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
