Question about Philips 60PP9352 60" Rear Projection Television
Picture but no sound
I have a philips 60pp9352 rear projection tv have picture but no sound. I have tried te mute, the audio selector and volume control. I have the cable box hooked up and a dvd plyer same on both.
  • 3,037 Answers
A defective audio output ic (integrated circuit) is most likely the problem. This is something that you want replaced by someone with electronic experience as it requires skills that most don't have plus working on a tv can be dangerous without experience so I recommend finding someone who can test to verify that the circuit is bad and then replace the part. Let me know if you need anything else. Sorry to be the bearer of bad news.
Benjamin
Posted on Apr 20, 2009
When I turn on my Philips rear projection tv, the power comes on but no picture or sound. power light stays lit solid. If i adjust slowly the screen or focus controls, the picture and sound will come on....
could be a number of things....check for bad solder connections on circuit board around Flyback xformer and also check connections on conversion module for colour problems....double images red , blue , green popping in and out.
May 19, 2010 | Philips 60PP9352 60" Rear Projection...
No picture No sound, chirping from a board
Is the FBT,the high voltage transformer.The big black block of plastic with a red wire solder to a board.MIght even have to change transistors deflection board also.
Nov 21, 2009 | Philips 60PP9352 60" Rear Projection...
I have 60" projection tv sometimes the picture goes scrambled if you hit beside power switch it comes back on. Sound is there just no picture.
HI,
Common problem on this set.
SSB ( small signal board) Bad.
This part cost about $135-$245.
encompassparts.com
provide model number tv and they will help you.
Thank you
Sep 26, 2009 | Philips 60PP9352 60" Rear Projection...
My philips 60" philips tv model 60pp9352 picture is squeezed at the middle (like an hour glass on its side), how can I fix?
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Mar 16, 2009 | Philips 60PP9352 60" Rear Projection...
No cable picture
Good Day, ant197904;
Sounds like you need service, try a video input, how does the DVD look, for your TV or Signal Provider. Good Luck, big IRISH.
Aug 22, 2008 | Philips 60PP9352 60" Rear Projection...
60pp9352- no picture
Goto www.magnavoxhelp.com. They have a kit that will fix this common problem.
Jun 14, 2008 | Philips 60PP9352 60" Rear Projection...
PHILIPS TV MODEL # 60PP9100D/37
check your speakers, your cables going to speakers and try to use a headset, if you hear sounds in your headset the problem is your speaker .
Mar 08, 2008 | Philips 60PP9352 60" Rear Projection...
No sound for cable tv
Is this cable connected up to your TV set thruogh the tuner, the RF input, or the video and audio outputs, scart connector? You may want to make sure the cable box does not have a mute or a volume control turned down, and make sure the TV's audiop setting is not on SAP. Good Luck
Apr 03, 2007 | RCA P56812BL 56" Rear Projection...
Red picture in panasonic 60" Rear Projection TV
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 27, 2006 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
