Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Mitsubishi VS60603 convergence
By nytshd on Sep 20, 2007
I was having problems with the convergence on this set. I located the service codes and adjusted the values but still couldn't get the arcs completely out. I replaced the STK modules as was recommended to me by a friend. The convergence grids are now almost straight and much clearer than before but won't adjust when doing the advanced convergence or the basic convergence.
Comments:
Sep 20, 2007
- Tried the resets. Convergence still won't adjust. Connection at VD good.
Same Problem
Jun 10, 2008
-   Two years ago I had exactly the same problem. With the remote I could line up the red, green. and blue lines pretty good but not perfect. The local tech for Mitsubishi told told me I neededa certain new board that controled thr convergence but Mitsubishi didn't manufacture that board any more. I called Mitsubishi customer service and they gave me a voucher for $750.00 towards a new TV. This board can be fixed if you can find a real tv tech and not just a parts changer, If you cant find anyone to fix it maybe Dave at Sy Electronics in Gilbert can help you find one, The number is 480-917-8889.-   dodger 1
May 28, 2008
-   Convergence problem present when tv is on for a while... once it cools off it is ok again. The blue is not straight it arch's thus making the white look yellow. I have a Mitsubishi ws-55905. -   qbnborn
Dec 06, 2007
-   the red line and blue lines are not converging.-   Guest
Best Solution
posted on Jan 15, 2008
Very Helpful)
refatb
Rank: Guide
Rating: 94%, 9 votes
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 23, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
bad chips need to re-weld convergence chips
Solution #3
posted on Sep 20, 2007
Somewhat Helpful)
troylove11
Rank: Wiz
Rating: 84%, 1287 votes
CHECK CONNECTOR "VD" FOR PROPER CONNECTION BETWEEN THE CONVERGENCE PCB AND CONVERGENCE GENERATOR PCB. 2. SEVERE CONVERGENCE DISTORTION BUT CONVERGENCE WILL ADJUST. THE CONVERGENCE EEPROM DATA MAY BE CORRUPT, DO CONVERGENCE RESET AND REALIGN THE CONVERGENCE. CONVERGENCE RESET CAN BE DONE SEPARATELY FROM E2RESET. (THIS IS NOT IN THE SERVICE MANUAL). ACCESS THE FINE CONVERGENCE MODE BY PRESSING MENU 23594 THEN PRESS 8970 TO RESET GREEN, PRESS THE AUDIO BUTTON TO CHANGE TO RED AND PRESS 8970 AGAIN TO RESET RED, PRESS THE AUDIO BUTTON ONCE MORE TO GO TO BLUE AND PRESS 8970 TO RESET BLUE
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
messed up service mode settings need to obtaim original settings for 42wh46 toshiba rptv
Answer
picture is only green and red and has ghost images also perfect focus does not work
Answer
our tv picture is only coming in red and green. what is the problem?
Answer
my projection tv is blurry like seeing double. the picture is bowed.
Answer
I noticed today that the bottom of my WD-60735 looks like a layer of something on the screen inside... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
