Question about Black & Decker String Trimmer Cordless 12" 18V
Replace Battery I am trying to replace the battery in a grass hog B&D trimmer. I have tried to remove the screws with a phillips head screw driver, but none of mine fit. Does this require a special tool to open the electric hub and replace the battery?
SOURCE: cst 1000 cordless trimmer battery
You've got to be kidding. My battery is useless after only about 5 years. I've already purchased the new battery for $35. Does anybody know how to replace it?
Posted on May 20, 2008
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 133 Answers
SOURCE: how to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Posted on Apr 21, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Grasshog trimmer line wont stop coming out and it won't break off
Rewind your string in the opposite direction than it is wound now.
If it is wound in the wrong direction it will cause the line to continue to feed out.
Good Luck, I hope this helped
Please do not forget to rate me,
Thanks
Posted on May 15, 2010
How to replace battery on a black and decker cordless trimmer
  • Remove battery pack
  • Unscrew screws with Philips #2 to remove cover plate
  • Suggest you take picture with smartphone / digital camera of layout before removing battery, so you can easily pit back correct
  • Remove battery - you can easily get a replacement at Batteries & Bulbs or online.
  • Replace battery
  • Reassemble per picture
  • Put cover back on
  • You should be good to go
Jun 04, 2014 | Black & Decker Cst2000 12 - Volt Cordless...
I need a new spring to replace the lost one that makes the spool advance. Its a Grass hog that is a few years old. Not battery powdered, but electric. Can yoy tell me where to buy one or what size...
They have upgraded the old string heads (type 1) to a new string head (type 2). They say type 1 is no longer available. Please see part numbers 20 & 21 in this 14" Grass Hog parts breakdown diagram. The new string head is relatively inexpensive. If you don't want to get one, could I suggest you take the old spring (if you have it) and match it up with possibly a new spring at the hardware store. Sometimes you get lucky! Here is the parts diagram for it. Hope this helps!
http://www.ereplacementparts.com/black-and-decker-gh1000-type-grass-hog-trimmeredger-parts-c-4167_9518_9532.html
Oct 30, 2010 | Black & Decker 14" Grass Hog Xp...
How do you take apart the B&D H1000 Grass Hog XP to get to the inside to replace the shaft? I thought I had removed all the screws but it still won't come apart. What am I missing? Jim
Jim-
From other google searching i found this:
"Charles, there's an additional screw under the label that instructs how to turn or extend the shaft. A white line separates the 2 instructions. The screw is directly above this line. Just punch through the label and you'll find it"
Apparently once you get inside (that's how i'm spending my weekend, too), it's $53 to replace the motor and gear. $69 for a brand new one...
k
Aug 07, 2010 | Black & Decker 14" Grass Hog Xp...
How can I remove the old spool kit from a grasshog xp1000? I have a new one to replace it but can't get the old one off.
After removing the screw, I had a heck of a time pulling off the old spool kit. I ended up running a rope through the holes that the cap clips into, stood on the rope and pulled up on the Grass Hog. Finally I managed to pull the old kit off. I managed to put the new one one, but I'm not 100% sure whether the cross-shaped piece at the bottom of the post is perfectly lined up with the new spool head. I was able to replace the screw and so far it seems ok.
Jun 04, 2009 | Black & Decker 14" Grass Hog Xp...
Head of trimmer/edger doesn't spin
i have the same problem, the plastic timing pulley on the motor assembly is probably melted, remove all the screws down the side of the housing, including the one hidden under the label, and you will find that the belt and the pulley are both chewed up.
Apr 18, 2009 | Black & Decker 14" Grass Hog Xp...
Battery replacement for unit
The unit itself is obsolete.
However....
Open the unit up (six cross-head screws). Inside you'll find a 12V 5.0AH rechargeable battery, like the kind used in many home alarm systems.
You can get a replacement at most battery stores (they'll even pre-charge it for you). Somewhere around $20, I guess.
Sep 12, 2008 | Black & Decker String Trimmer Cordless 12"...
12 volt grass hog cordless
there should be 2 screw that holds the top cover.before that u have 2 release/remove the handle first.
Jul 30, 2008 | Black & Decker String Trimmer Cordless 12"...
Grass Hog Battery #243215 (12 VDC SLA) and Charger #371415-11
May 22, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
119 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
