Question about Palm Zire 71 Handheld
Zire 71 digitizer
When I did a reset I cant seem to get out of Tap screen of digitizer it just keeps going
    New Friend:
  • 3 Answers
Hi, I had the problem after the battery was discharged for a long period. when i charged it and turned it on, i got the message "tap the center" but with no luck. i found out that the lipo battery in the palm was like inflated to double size and therfore was pressing on the backside of the screen, as i removed the back cover it vorked just fine ( if you want to turn it on when the back cover is off, there is a "sabotage" switch you have to press to make it operate, it is located just behind the on button)
Posted on Jan 19, 2017
I have the same problem and discovered that the right side of the screen had "spread". When I draw a line from the left to the right using Note Pad, the line ends up about 1/4 inch above the stylus. What I had to do is touch the stylus about 1/8th of an inch above the center of the digitizer target on the right side.
Posted on Oct 02, 2007
SOURCE:
I replaced the Battery in my palm Zire 71 and two pieces that fell out and then when i put it back together with out them the camera wont come on at all I have the pieces but I just need to find out w
You aren't going to find that information anywhere. My advice is to either return it to Palm, or buy a spare one. There is one for $4 that needs a charger.
Palm Zire 71 Repair
Palm Zire 71 Take Apart Directions - DirectFix
www.directfix.com/category/_ZIRE71_TAKE.html
iPhone Replacement Parts? We offer iphone parts for cracked iphone screens. DirectFix offers iphone screen replacement parts, iphone repair parts & iphone ...
Palm Repairs ' palmdr.com
www.palmdr.com/pda-repair/palm Tungsten T, T2 and T3 Repair Form. Zire Series Models Zire 72 Choose either our Repair Form or Express Repair Service Zire 31 Repair Form Zire 71, Zire 21, ...
Zire Series : PalmDR.com, PDA Repair Done Right!
www.palmdr.com > Home > Accessories Products 1 - 12 of 27 - PalmDR.com : Zire Series - PDA Units Accessories Printers Repair ... Perfect fit screen protectors for your Palm Zire 71 or Zire 72 PDA unit.
Palm Zire 71 PDA for Parts or Repair • $4.00 - PicClick
https://picclick.com/Palm-Zire-71-PDA-for-Parts-or-Repair-192159832687.html Up for auction is a for Parts or Repair Palm Zire 71 PDA for Parts or Repair This is in excellent physical condition but I do not have the charger 192159832687.
Palm Zire 71 PDA for Parts or Repair 805931008343 ' eBay
www.ebay.com > ... > Gadgets & Other Electronics > PDAs > See more Palm 71
Rating: 4.5 - ‎80 reviews
This is sold as is for parts or repair. This is in excellent physical condition but I do not have the charger to test. I do not know if the battery is good or bad or if it is ...
Palm Zire 71 Blue PDA Organizer - Bad Battery - For Parts/Repair
www.ebay.ca > Consumer Electronics > Gadgets & Other Electronics > PDAs Palm Zire 71 Blue PDA Organizer - Bad Battery - For Parts/Repair in Consumer Electronics, Gadgets & Other Electronics, PDAs ' eBay.
Jul 25, 2017 | Palm Zire 71 Handheld
Malfunctioning keyboard. If touch a letter A a different letter will come up. same thing trying to use the calculater.
the screen needs calibration. below are the instruction on how to calibrate the screen. The Digitizer Preferences screen opens the digitizer calibration screen. This is the same screen that appears when you start your handheld for the first time. You can recalibrate your screen after a hard reset or if your digitizer drifts. You may need to repeat this process a few times until the calibration registers. To calibrate your handheld screen: 1. From the General Preferences list, select Digitizer. 2. Tap the targets as indicated on the screen as precisely as possible.
TIP You can also press Left, Right, Up, and Down on the navigator to highlight a Preferences screen name and then press Select on the navigator to open that Preferences screen.
Aug 04, 2010 | Palm Zire 71 Handheld
Zire 71 screen does not sense stylus input -- even after performing a reset.
HI,
Try doing a hard reset. This will erase everything on your zire and restore it to brand new settings. To do a hard reset make sure you have everything backup on your palm desktop. Here are the steps for the hard reset:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus2.gif.
2. Continue to hold them both in until you see the Palm2.gif logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync. It should clear up your problem. Best wishes.
Oct 10, 2009 | Palm Zire 71 Handheld
Turn it on it says Set UP using stylus. But nothing happens.
The digitizer is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Best regards,
May 28, 2009 | Palm Zire 71 Handheld
Zire won't come on
You need to follow the procedure to calibrate the digitizer.
If the screen does not respond to the stylus, then the digitizer is defective and needs to be replaced.
Best regards,
Feb 11, 2009 | Palm Zire 71 Handheld
Palm Zire 71
The top plastic digitizer is defective.
It needs to be replaced.
There are several sources on-line to buy such digitizer part.
Best regards,
Jul 14, 2008 | Palm Zire 71 Handheld
Goofy thing going on
Try resetting the digitizer on the Setup programs, it works for me, but needs resetting every so often. a lot easier (and cheaper) than buying a new screen for such an old machine.
Jul 10, 2008 | Palm Zire 71 Handheld
Palm Zire 71... mind of its own
first use the digitizer in the prefs program on your palm
if that doesnt work someone or something has damaged your screen by pressing too ******* it and youll need to find a screen replacement Palm offers the safest and best job for 140 or something like that i recommend going somewhere else (to save money), just do some research and know who you're sending your palm to first
May 29, 2008 | Palm Zire 71 Handheld
My palm zire 71 does not ever synchronise to mi laptop
You can check in PalmOne web site the user manual for such PDA.
There are all the instructions in how a synchorinzation is done, and how to add new applications to it.
Best regards,
Jan 20, 2008 | Palm Zire 71 Handheld
Zire 71 collected moisture
The digitizer function reads from the input of the LCD touch screen, so I would say LCD.
Dec 22, 2006 | Palm Zire 71 Handheld
Palm Zire 71 Handheld Logo
187 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
