Question about Drive Deluxe Fly Weight Aluminum Transport Chair, 19" Seat
Drive Fly Weight Wheel Chair
I am looking for a kit that can be used to extend the brake handles on this wheel chair. Any suggestions are appreciated.
There are several ones that i have seen on the net on medical or wheelchair sites. It usually is a long handle that the hole is a little bigger and just slides over the existing break handle. or fits inside. Here is a link that has one like I am talking about.http://www.allegromedical.com/wheelchair-accessories-c545/6-wheel-lock-extension-for-wheelchairs-p555836.html
Good Luck :)
Posted on May 26, 2009
  • highestbowle May 26, 2009
    Not sure if i put the link in so that all you had to do was click on the link, so I will try again.
Hi, my mother's mobility scooter won't work. The power button flashes constantly. Any ideas how I can fix it?
Many times a brake lever reset can resolve this issue that is preventing the PWC from operating.
MPV5 Power Wheelchair Break LeversMPV5 – The brake levers are located on the front of the Power Wheel Chair just above the footplate. To reset the brakes on the MPV5 Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
FWD and XHD power chair break releaseTEK FWD and TEK XHD - The brake levers are located on the front of the Power Wheel Chair under the label that reads “Drive” and “Push”. To reset the brakes on the TEK FWD or XHD Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
If the lights on the controller continue to flash make sure the controller is not locked.
Apr 14, 2016 | Health & Beauty
Free wehee lever repair
The free-wheel lever actually disengages the automatic electric brake so that the chair can be pushed. The brake is what holds the lever in either neutral or drive. Could be that your electric brake is shot.
Apr 07, 2014 | Shoprider Wizz Power Chair 888WNL by
Lights turn on cant move
Be sure the free-wheel \ brake release handles are set to drive\lock position prior to turning on. After that, if chair still does not move, you will need to count the flashes on the joystick to determine the error or issue with the chair.
A user manual can be purchased on ebay.
Nov 11, 2013 | NRS Hoveround MPV 5 - Used Power...
Wheelchair brakes
hmm what make is it,every chair is different, but most have a setscrew on the back on the frame loosen it and slide back towards wheel and retighten,good luck with that
Nov 04, 2013 | Drive Health & Beauty
Golden compass power chair
Each wheel is run by a separate motor. This looks like either bad controller box, or bad motor. If it starts out working fine, then the one wheel stops after a short period of time, then it is probably a controller at fault. However if the motor is overheating due to mechanical binding such as a brake failure (the parking brake) or lacks lubrication causing excess power consumpltion, then the controller will shut down at some poiunt to avoid damaging itself and/or the motor. have a helper put the chair up on cememnt blocks, or woodne boxes etc, so you can observe it running. Listyen to the motor by doing left full and right full turns. The motors should be equally quiet and run at the exact same speeds. Dragging noises indicate a problem. be sure your parking brakes are disengaged. Now with the chair off, rotate eaach wheel by hand. They should need the same amount of force to move. if the bad wheel is harder to turn then it may need replacing or has bad brushes, brakes binding or in most cases dried up grease in the gearbox.
Feb 19, 2013 | Golden Technologies Alante' Power Chair
Hi, I have a jet 3 ultra chair . I have just put new batteries on and can still only do about 4 miles from a full charge, any ideas, Many thanks Rolfe
Rolfe could be a couple of things check the brushes in each motor for excess wear and check to see if the motors are getting overly warm after driving for awhile if they are then you could have a brake problem on one or both of the motors. If your brushes are less than 1/8" long then they need replacing and you can have a provider order some from Pride for you or have them service the motors for you. If it is the brake then it will have to be replaced by a tech who knows what to do if you can get the brake from Pride. Now I'm not suggesting this or recommending this because of safety and liability issues but you could remove the brake from the rear of the motor that is getting hot (if it is) leaving the wiring connected and hang the brake in the rear of the chair so it won't break the wiring and drive the chair to see if that makes a difference. If you remove the brake and wiring then the chair won't move at all because the controller is looking for the brake when you turn on your chair if the wiring is disconnected you will get a fault error and the chair won't move. Also have someone load test your new batteries just because"new" doesn't mean good and a weak battery will reduce distance driven. Hope this helps
Mar 18, 2011 | Pride Mobility Products New Pride Mobility...
I have a fairly old 1121 but cannot find any levers to go into freewheel. I have seen a modern one and can see them in that. Can you help?
Jackie I looked on the Pride Website and threy showed them behind each drive wheel above the motor facing the rear of the chair. Lift to place in freewheel and push down to engage. I hope this helps you
Oct 12, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
How to install sound device
I think your question is in the wrong category. You cannot install sound speakers to a wheel chair.
Jun 01, 2010 | Drive Deluxe Fly Weight Aluminum Transport...
Sunfire power chair won't charge but lights up when plugged in
you need to have the batteries tested it is possible that if left in a discharged state for an extended time that thee batteries may be damaged and will not be able to be recharged
May 24, 2010 | Pride Mobility Products New Pride Mobility...
How to push the jazzy wheel chair when power fails''
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
Jul 01, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Drive Deluxe Fly Weight Aluminum Transport Chair, 19" Seat Logo
66 people viewed this question
Top Drive Health & Beauty Experts
Colin Taylor
ray gallant
Are you a Drive Health and Beauty Expert? Answer questions, earn points and help others
