Are you getting a H2 error code? If the code dose not clear you may have a problem with the fixing unit... You may have a blown Heater lamp or thermister thermal fuse or one or two of these items..... You will have to trouble shoot to see what is wrong and repair it before you can reset it.. Good Luck
i have a sharp xv-zw99u projector. the bulb will only stay on for 5 minutes and then goes out.led...
(More)
I HAVE A SHARP XV-ZW99U PROJECTOR. THE BULB WILL ONLY STAY ON FOR 5 MINUTES AND THEN GOES OUT.LED LIGHT ON FRONT OF PROJECTOR FLASHES FOR FOR A FEW MINUTES THEN BULB TURNS BACK ON. THIS SEQUENCE KEEPS REPEATING.ANY IDEA WHATS WRONG ???
Docucate copier ( multi function) machine model CD 250 IN what model sharp is this ? what toner does...
(More)
Docucate copier ( multi function) machine model CD 250 IN what model sharp is this ? what toner does it use ???
have a docucate multi function color made by sharp but labeled dupli - model cd-250in what sharp...
(More)
HAVE A DOCUCATE MULTI FUNCTION COLOR MADE BY SHARP BUT LABELED DUPLI - MODEL CD-250IN WHAT SHARP MODEL IS THIS ? NEED SERVICE AND BLACK TONER
