Question about HP 1240 Plain Paper Inkjet Fax
Changing user name on used machine
When faxes are sent or received the name is wrong. it is set up for the previous owner. need to change this and i have no manual.
  • jmryland Nov 28, 2008
    Product: Canon phonefax B640 - need to change the header phone number and name
  • 163 Answers
There is the HELP key on the pannel board press it and go in the user data so you can find your desire setting or go by function key
Posted on Sep 21, 2007
SOURCE:
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Mar 24, 2013 | Ricoh Aficio Office Equipment & Supplies
I have a previously owned dell inspiron and I need to change the username from the previous owner
1.click start menu 2.click control panel 3.click user account 4.click the formal owner username 5. you will see various options one of which is change username, then click 6.enter your desired username and click ok
Jan 30, 2011 | Computers & Internet
I dont know who to change the phone number on the out going cover page so the receiver has a fax number to send back papers sent
If you don't have a User's Guide, go to the Brother web site and download it. But as a quick fix, you can access the menu function and navigate to settings and find the outgoing fax number place. Then you can change the number and name as you desire.
Jan 24, 2010 | Brother IntelliFAX 1570MC Plain Paper Fax
Given a Brother 590MC FAX machine, Need to remove previous detail
You can go under (menu) and then (Initial Setup) and using up or down tabs move till you see Machine ID. Press (menu) or (ok) button and change phone, fax number, and name. Press(ok) button after each is set to your specification. Hope this helped!
Mar 13, 2009 | Office Equipment & Supplies
Printing wrong fax number on paper headings
HI
Cant find a manual for that model but this is close enough for changing the details i think.
Download it from here
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IMAGERUNNER%202025I-_E
Feb 16, 2009 | Canon imageRUNNER 3035 Black and White...
Can send but not receive faxes
No identification is not the problem. It sounds like you have it set to "manual receive" rather than "auto receive"
Jan 28, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Want to change the Header
Press Data registation,on usersettings press set,press the arrows untill you get unit name,press set,insert you company name there.
To change the fax number-under usersettings select unit number and change it to your number.
Jan 12, 2009 | Canon LaserClass LC 8500 Plain Paper Fax
Need to change name and number
Press the MENU button and press 7, then 2 on the numbers keypad. You can then use the keypad to change the fax header. Press the keypad numbers corresponding to the letters you need. It will cycle through lower case first, then upper case. Press the RIGHT arrow button to advance one space between letters.
Jul 18, 2008 | HP 920 Plain Paper Fax
Sending Faxes
there is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
May 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Canon Fax Machine Super G3 High-Speed Facsimile
The header needs to be changed in the User soft switches under "User Settings" - Unit name and Date and Time. Settings differ slightly depending on the model. Please stipulate the model name for explicit instructions.
Jan 07, 2008 | Office Equipment & Supplies
HP 1240 Plain Paper Inkjet Fax Logo
67 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
