Question about Sharp AL-1655CS Laser Printer
Hp psc 750
I've just hooked up this printer/copier/scanner and there is a horrible grinding sound and the message on the screen says open door, clear cartridge jam, and press enter. I've removed and replaced ink cartridges and this problem still continues! What should I do?
Is there somewhere that shows how to get into this gear to replace it?
Posted on Dec 11, 2007
  • 186 Answers
Very common problem with this model, the gear that drives the fuser (the hot part) breaks. If you are not a tech I would bring it into a shop. Also ask them if they can replace just the gear and not the whole fuser. (much cheaper)
Posted on Sep 20, 2007
Align page not detected error on HP PSC 750 printer
Need to replace all print head with error or nozzles block
and try for alignment
once the page is printed it needs to be scanned to save alignment
if still get same message need to check for scanner functionality
Nov 08, 2009 | HP PSC 750 All-In-One InkJet Printer
Scanner not found
I HAVE THE HP PSC 750 NEED THE THE RESOLUTION FOR THE SCANNER TO WORK LOST DISC TO DOWNLOAD . HOW CAN I GET THE SCANNER TO SCAN.
THANKS EVI
Apr 04, 2009 | HP PSC 750 All-In-One InkJet Printer
Scanner error
You may want to try resetting the printer to see if the error can be cleared. If not, you may have a hardware problem that will reqiure service to correct the issue.
HP PSC 750 All-in-One Printer
Printer Partial Reset:
1. Hold down the "Cancel" and Left Arrow buttons while plugging in the power cord.
If that fails you can try a "Hard Reset".
Printer Hard Reset:
1. Verify that the unit is switched on.
2. Remove the power cable from the back of the machine.
3. Wait 30 seconds.
4. Press and hold the POWER button on the front panel.
5. Reinsert the power cable in the backside of the unit.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00060793
Mar 04, 2009 | HP PSC 750 All-In-One InkJet Printer
My hp psc 750 all-in -one printer scanner not working
A friend of mine had a HP printer (Not a PSC 750) that he had simply plugged into his computer and was able to print properly but received the "options not set" message when he tried to scan.
The solution was to install the HP driver package for his printer.
If you are using the default Windows drivers for your printer you may need to install the HP driver package to access all of your printers functions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&custom_solutionid=rd_bpu04809&product=57769
Mar 03, 2009 | HP PSC 750 All-In-One InkJet Printer
Open Door. Clear carriage jam, and then press Enter
Sounds like you have a jam. Open the back of the printer and checl for any paper large or small. If there is no paper, just opening the door and closing it may get rid of the message. All it takes is a piece of paper the diameter of a pea to send a signal that there is a paper jam. After yuou have finished close the door and push enter to let the printer know you are finished. See if this helps. I don't think it has anything to do with the ink cartridges. It sounds more like something stuck causing the jam. Be sure not to have anything like a staple attached to the paper you are printing on to. A speck of dirt could casue a jam message too.
Aug 28, 2008 | HP PSC 750 All-In-One InkJet Printer
Place align paper on scanner glass
1,Unplug the USB cable
2,Place the allignment paper in the right bottom corner of the scanner glass
3,close the lid
4,Press the Start scan button
You will find the light blinking wait until it completes.
Then connect the cable and the issue will be resolved.
Hope works well for you
Apr 29, 2008 | HP PSC 750 All-In-One InkJet Printer
Hp psc 750 cariage problem
Hmm...
Look inside the printer for anything that shouldn't be in there... like paper or dust.
Cariage jam is shown whenever the carriage is blocked by something... even the service station (the black container in the right where the cariage sleeps). With the printer cover open try to power up the unit. Look where the cariage stops. Ceck with a flashlight for any obstacles in that area. Olso verify if the service station is moving. It could be broken and the cariage cannot move away from it.
Jan 02, 2008 | HP PSC 750 All-In-One InkJet Printer
Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
Sharp AL-1655CS Laser Printer Logo
78 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
