Question about Kenmore 56939 Side by Side Refrigerator
Strip felt hot to touch between fridge and freezer sides and coil appeared red -orange when bottom storage shelf was pulled out on the freezer side. is this a compressor problem?
My wife noticed that the strip between the freezer side and the fridge side was hot to touch and when she pulled out the lowest drawer on the freezer side, a coil looked red-orange. she of course unplugged it. she looked at some other web site and it mentioned it could be a compressor problem. the fridge was bought new 2 1/2 yrs ago sears kenmore side by side, model 106.5693*600. what are your thoughts. thanks
HVACRH20
  • 237 Answers
SOURCE: Kenmore 596-76512 fridge not cooling freezer seems to be working still
If the fan above the evaporator coils in back of the cover isn't running then no cold air will be blown up to the fridge area. That's a common failure item and very easy to replace yourself. And by the way... $200 bucks and 2 weeks out is about normal these days believe it or not. It's what we would charge ya! :) At least you did the troubleshooting and saved yourself a couple hundred bucks.
Posted on Jan 15, 2007
catriver
  • 878 Answers
SOURCE: Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
Posted on Aug 05, 2007
SOURCE: Kenmore side by side no longer freezing on freezer side and not as cold as it should be on both sides
We had the same thing happened. We called Sears and scheduled a repair. Apparently there is a small electric heater that keeps the coils from freezing up and had to be replaced, about $80, I think. Not sure if that is your problem.
Posted on Mar 03, 2008
SOURCE: Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Posted on Jun 16, 2008
  • 958 Answers
SOURCE: OVERHEATING COMPRESSOR
you can check its starting components. it could be a bad capacitor or a bad start relay. if the compressor starts from cold, it could start right away but as it heats up, it should be able to start also, since after running for a few hours, the compressor will really get hot, it would stop at defrost cycle and re start again after about 30 mins. since it is still hot, if it has a defective starting components, it can not start and that is the time it would overheat.
in any case that the starting components are all ok, then you have a partially burnt compressor. it would run while cold and can not run when hot because the resistance of the wires changes as it gets hot. with this kind of problem, you need to replace the compressor. as you have said, the fan at the condenser is running. if the fan at the condenser is not running, that is also a cause for the compressor to overheats. i hope i was able to help...
Posted on Jul 05, 2008
The dividing strip between the freezer & fridge is hot.
Pull the refrig out and remove the rear cardboard panel . Check to see if something is caught in the fan blade stopping it from turning . Also , make sure the black square coils are clean . If the fan is not turning , and no obstruction , replace the fan motor . Use a small house fan to cool the compressor until the motor is replaced or the compressor could stop working .
May 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
The strip between the freezer and refrig door is extremely hot. Never felt hot before. It is not the door, but the refrig and freezer itself. The refrig is still cold and freezer is frozen.
The heat you are feeling is normal, I wouldn't worry too much about it. If you start having a problem with cooling you may want to look into getting a repair guy to look at it but many refrigerators will heat up in that strip between the fridge and freezer.
Dec 12, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
I have GE side by side fridge. The freezer built up frost and then started to defrost. I took everything out andoened the back panel. The freezer was getting cold again but frost on the coils. the fridge...
Pull refrig out from the wall and unplug . Remove the 8" x 10 " panel covering the main control board . On this board , unplug the blue plug with 3 larger wires going to it . The sequence looks like this : wire1,wire2,space,wire3 . Use a piece of wire , with both ends stripped about 1/4 " , and insert an end into wire2 and wire3 . Plug refrig back in . Look inside the freezer at the back bottom , and see if you see a red glow . It may take about 30 seconds for the glow to appear . If no glow appears , the defrost heater located at the bottom of the coils ( glass tube ) is probably shorted . Pt # WR51X10042 . Also replace the defrost thermostat Pt # WR50X10068 . To access these parts , the inside freezer panel has to be removed . If you do get a red glow , then the main control board is bad Pt # WR55X10656 .
Sep 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Back wall freezes up on freezer side while fridge side is too warm. fridge temperature stays between 60 to 70 degrees
Is the freezer fan working ? If not , control board probably bad . Pull refrig out from wall and remove power . Remove the 8" X 10" panel and you will see the main control board . Remove the blue plug with 3 larger wires . The sequence is : wire1 , wire2 , space , wire3 . Using a short piece of wire with both ends stripped about 1/4 " , insert the wire into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom rear for a red glow ( may take a minute or so ) . If you see a red glow , the main control board is bad ( the board you unplugged the wires from ) . If no red glow , then disconnect power to fridge , remove the jumper , and reinstall the blue plug and the panel .
Remove the food from the freezer section and remove the rear freezer panel inside the freezer . There you will see a round 1 " disk , clipped on top of the coils .Pt # WR60X10068 Defrost thermostat . At the bottom of the coils , you will see a heater . Pt # WR51X10042 Defrost heater . Replace both of these as the heater gets hot , and cuts off by the bimetal . he heater only has a screw on each side attaching it to the coils , and the bimetal just clips on . Easily repairable .
Aug 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire #FRS24XHA is hot to touch and freezes food on the left
Hi: Those areas are designed to be warm to keep moisture from forming there(Moulion coil). When they get hot it means the fridge is over working. The condenser coils remove the heat from the fridge. When clogged the heat will leave anywhere it can. The moulion coil is the strip you described,and will overheat when the condenser coils wont disperse the heat. Most likely the coils need a good cleaning, on the bottom of the ref. Use a coil brush and a vacuum. Or even an air compressor to blow the dust and hair out; plan on dusting the house too. Pull the grill off the front and clean them. If real bad pull the panel of the lower back and clean it out too. Since you work in detroit the dust and hair on the coils would be like putting a blanket over your radiator. Parts would heat up. I hope it's just the coils. If a compressor is failing you can get the same symptoms. I hope it is the latter for you, as I'm in your boat also. I hope this helps, Jeff
Jun 09, 2009 | Frigidaire Refrigerators
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Kenmore 56939 Side by Side Refrigerator Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
