Question about Electrolux Ovens
Zanussi zbm 140 built in oven - need new door seal
oven door needs new seal - who can i contact in melbourne to replace door seal
VOTIT
  • 2071 Answers
SOURCE: how to remove the glass from zanussi oven door
There are 3 'Do-It-Yourselfer' stories about installing this part
Posted on Jul 13, 2008
  • 120 Answers
SOURCE: Removal of Zanussi oven door
Hello tracey,
Yes i may be of assistance to your dilemma, if you notice the hinges on the bottom of the door you should be able to open it slightly and gently but firmly pull upwards and outwards which will allow the door to prop off. i would suggest placing the door on either cardboard or a soft rug. If this is not the case please write back and i would gladly help.
Please post what you do and how you did it I look forward to your posts
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Zanussi electric oven ZBM 762X How do I trun the oven to manual?
If it is an anologue timer then rotate the knob until you see a hand symbol in the window, this brings it off auto.
If it is a digital timer then you need to press two or more buttons at the same time to get it off auto and back onto manual.
Posted on Dec 08, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven keeps tripping the electrics
I would suspect that the fan oven element is faulty. what I think is happening , is as the element gets hotter, the insulation is breaking down and causing the trip to operate, it is quite a common problem
You will need to fit a new element.
If it is a fan assisisted oven you will find the element behind a removable cover at the rear of the oven compartment..
Plz rate my solution.
Thankyou.
Posted on Jan 06, 2009
SOURCE: oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Posted on Feb 28, 2009
Should my new zanussi built in double oven have a grillpan handle & oven tray provided?
It certaily should, if they are not with the oven, then I would contact the people who supplied the oven in the first place, and request the pan etc.
Dec 21, 2010 | Zanussi Ovens
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
Can i purchase a replacement seal for around the
That seal you should be able to order from any appliance spares supplier the Zannussi part number is. 3577252020. cost in euros. € 10.20 + vat.If it is the one I think it is then it is not easy to fit.The screws around the whole front panel have to be slackened off and the front prised forward dont take off fully pull old one off the new one has to be pushed in behind lip then fix all screws.may be easier with door off.
Hope I helped.
Apr 25, 2010 | Zanussi ZBF260 Electric Single Oven
How do I get the inside glass panel back onto the door?
You will find sets of screws ether on the outside edge of the door OR on the inside panel. You can NOT! use any glue to "seal" the Glass this will make everything smell like the sealant you picked to use. your door was probably used as a resting spot for something heavy and caused the doors skin to be bent OR when you Cleaned the oven with the clean feature it caused the door to warp. Your option is to get a replacement part to fix the problem you can stop by any appliance parts shop and ask them what the best thing to do is and/or buy the part there you can "pull the door" off the hinges by lifting the door straight up at you and take the part to the stop for help and or replacement
Feb 10, 2010 | Zanussi ZBF360 Electric Single Oven
How to fix iner seal on the oven door
I have a Zanussi ZDF290X which requires a new top oven seal. I have pulled the remainns of the old one out, but without dismantling the oven it seems impossible to fit the new seal. Any easy way of fixing this, please?
Jan 13, 2010 | Zanussi Ovens
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Door seals need to be replaced
first thing to do is to obtain a new one before you take out the old one. most stoves you just slide it into the grove, like a track
Aug 10, 2009 | Zanussi ZBQ365 Electric Single Oven
Need English user guide for Zanussi zob 662 x
zanussi built in single oven outer glass door has just exploded any similar problems or reasons for this
Mar 29, 2009 | Zanussi ZBF360X Electric Single Oven
Dec 08, 2008 | Ovens
Hello tracey,
Nov 11, 2008 | Zanussi ZBQ665 Electric Single Oven
Ovens Logo
93 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
