Question about Sharp Aquos LC-32D40U Television
Sharp aquos model LC-32D40U screen goes black
When turning the tv on it sometimes will display and then go black after a few seconds or it will not display a pictuere at all or it will come on and work like it should... Could this be a power supply problem/ or perhaps the backlight is bad?
  • rcdorrjr Apr 20, 2009
    Thank You... I will have the inverter board checked out at once...
The Sharp TV model LC32D40U / 41U "Black Screen problem" is a very well known issue. The inverter is losing ground contact which will prevent the back-light from staying on. The solution is to re-tighten six screws on the inverter board. You also would want to clean the copper contacts on then bottom of the inverter where the screws go through. Access to the inverter board will require some disassembly. Plan on taking at least three hours to repair. See the photo for the location of the screws. Use some "blue" locktight" on these six screws. There is actually a Sharp Technical Service Bulletin that describes these screws. Sharp wants you to replace these screws with a newer version. They cost at least $2.50 each! I think my method will work just as good using the "Locktight"sharp aquos model LC-32D40U screen goes black - _548.jpg_547.jpg
Posted on Jan 24, 2011
  • WillisBryan Feb 19, 2011
    I had the same problem with the back light going out. I too found the screws loose and small burn marks on the copper and metal shell. Cleaned all the lands and put it back together with blue "LockTight". Preliminary on this fix looks good. FYI: I put the 6 screws back in and over 5 minutes went back and resnugged each one several times. I also went around to the other boards and snugged their screws as well. Found several with ground tabs somewhat loose.
    This repair does take some time as there is a lot of dis-assembly to do but the fix was free.
    Good hunting, Willis
    President:
  • 1,077 Answers
Most likely the backlight inverter board. I would try replacing it, it's cheaper than buying a new TV.
shopjimmy.com is the best place to get parts for a good price.
Here's the page for backlight inverters:
http://www.shopjimmy.com/catalogsearch/result/index/?q=lc-32d40u&p=6
There seems to be two different inverters.
"RDENC2266TPZ" and "250000007800"
The RDENC2266TPZ seems to be of stock.
But, the 250000007800 is in stock from this TV. It's the same part#, so it's interchangeable.
http://www.shopjimmy.com/back-light-inverter-250000008700-from-sharp-lc-32sh20u-4.htm
You'll have to find out which one is the correct board. Your board in the TV should have the part# on it.
Posted on Apr 20, 2009
Thanks for the solution dsacco, although your solution may just be a temporary fix. Here is my experience: I have a Sharp LC 32D40U, and had exactly the same problem last year. I had it fixed locally, paid $190 (parts and labor) and told me they replaced a "board". Exactly 1 year after the repair, the same exact problem started happening again. Of course the repair warranty is only 90 days so it would probably cost me another $200 to get it fixed again. I called the shop that fixed it previously and they would only give me credit for the labor if it is in fact the same problem I had before, I still have to pay for the part. If it is a different problem, they will have to charge me for labor again. I think I may be coming out ahead if I just give up on this Sharp, since I can buy a brand new 32" Vizio for less that $400.
Posted on Jun 05, 2009
Sharp lc-32d4ou screen blacks out
I do have a work around that I have used on this model for the past3 years. if the sceen goes black. Turn off the tv. Grab the upper left and right hand corners of the tv with your hands. Flex the tv slightly back and forth. then turn it back on. my will usually run for hours after I do this. I do this 4 times a week. I works 100% if the time for me. Sharp lost a customer. good luck.
Aug 31, 2010 | Sharp Aquos LC-32D40U Television
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Video goes black on startup
sems like your pisture tube for the tv is going slowly out. replace the tube or replace the tv, its cheaper to replace the tv then a new tv screen colour tube.
Aug 23, 2008 | Sharp Aquos LC-32D40U Television
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Sharp Aquos LC-32D40U-picture goes off at random times
The bad news,your set needs a new inverter board installed.With persistence to sharp,you might be able to get them to pay for the parts.
Jan 10, 2008 | Sharp Aquos LC-32D40U Television
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Probelm with wide screen display .
Check your VIEW MODE button instead ....
Aug 17, 2006 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
2,997 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
