Question about Kenmore 22622 Top Load Washer
Removing tub Which way do you turn the spanner nut to remove it. cw or ccw?
  • 878 Answers
Counter clockwise. Catriver
Posted on Sep 20, 2007
Nut hot faucet
Hi Lee, CCW Lefty loosey, Righty tighty, LOL Have fun at it.
Sep 20, 2013 | Kohler K-10270-4-BV Forte Two Handle...
Fan Clutch R&R With Confidence Using Griller....Glitter Tool
...ever found you self asking which way to turn a mechanical fan clutch's inline coupling nut to remove clutch-fan assembly (It) without mangling a thread or special wrench? Well then, consider the Griller...Glitter mnemonic system described below and never fail to be "thread-wise in the know."
If you know or can bump the starter to see which way the fan spins viewed from the radiator, then knowing any or all of the easy-to-remember devices below will let you get that clutch off, or on, with confidence. For instance, with a left thread clutch nut, the installed clutch-fan assembly will always spin right/clockwise.
Remember, you only need to remember the ones that are easy to remember.
    ·If fan clutch spins right/CW, turn its nut right/CW to loosen.
    ·If fan clutch spins right/CW, turn its nut left/CCW to tighten
    ·If fan clutch spins left/CCW, turn its nut left/CCW to loosen.
    ·If fan clutch spins left/CCW, turn its nut right/CW to tighten.
on Jan 12, 2015 | Vehicle Parts & Accessories
How do i remove the fan and pulley on a 1987 ford ranger 2.9 v-6?
The question is: How remove clutch in order to remove fan mounted on its engine-side face.
  • Generally, the clutch drive half shaft must be uncoupled from coolant pump (impeller drive) half shaft using special wrench kit available as loaner from AutoZone (free with $79 approx deposit).
  • Best done after shroud & radiator remove after coolant drained.
  1. Uncouple coolant pump and fan clutch drive shaft(s) as follows:
    1. span across combo-pulley-sheaves-unit mounting bolt heads with large tool kit wrench, and
    2. span inline clutch coupling nut with small tool kit wrench. Then,
    3. turn small wrench (and coupling nut) CW while resisting with large wrench (CCW) to turn coupling nut until disengaged from coolant pump drive shaft.
  2. Remove fan/clutch assembly.
  3. Note direction of mounted fan hub and fan blades orientation to ensure proper re-assembly.
  4. On rear of clutch assy, remove 4 bolts to disengage and remove fan.
  5. Assemble new fan to clutch (or, preferably, new clutch and new fan) using new bolts and washers provided with fan.
  6. Couple fan-clutch assy to coolant pump drive shaft as per opposite of uncoupling step 1, above. (Turn inline nut CCW to tighten...30 ft-lb.
  7. Check that fan can be hand turned...CW.)
  8. Rest shroud over and onto fan.
  9. Replace radiator; remount shroud; reclamp hoses, and refill and air purge cooling system.
Aug 12, 2012 | 1987 Ford Ranger
You can replace bearing for the tub.Instruction are here. disconnect the wire remove front panel top panel and pull cover out remove the screw need a spanner nut wrench to unscrew turn cloclwise remove the tub cone and spinning drum remove the screw .
Jun 20, 2011 | Frigidaire GLWY1343AS Top Load Washer
How do I remove the spanner not from the shaft on my kenmore 110.9228110
Right hand threaded nut holds tub in place is direct drive, top loading washing machines. To remove the spanner nut you will need a spanner wrench
May 31, 2011 | Kenmore Washing Machines
INNER TUB REMOBAL: Tryng to get to the drum
See the following:
A number of the diagnostics and repair procedures for these washers require you to remove the agitator(s).
In order to get the agitators out, you need to remove the "Spanner Nut" and "Drive Block".
Many instructions call for a special spanner wrench to remove the nut. However,
You don't need a special spanner wrench. (About $20 retail)
I've used a short 10" pipe wrench (About $9 also good for cracking walnuts) hooked around one of the tabs on the spanner nut and tapped the handle with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
Also see the Whirlpool Service manual for these washers with diagrams of the springs.$FILE/L-55.pdf
The tub is attached to the triangular support from below with a spring and two screws.
Once the screws and springs are removed, you should be able to lift the tub up.
Apr 09, 2010 | Kenmore Washing Machines
Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.!retrieve.pd?modelNumber=110.82372110
The following may also help.
Jan 25, 2010 | Kenmore 22422 Top Load Washer
Water came out both shower head and tub spout (even w/o spout)
The shower valve is clearly mark "UP" when you look at it from the front.
Nov 17, 2009 | Plumbing
LWR50AW 9904000131 is leaking from the bottom of the center of the machine. How do we take it apart to solve this problem? Thank you, Norma Marchant
You'll need to replace the transmission seal. For this repair job you’ll require special tools like T20 Screwdriver and other similar tools. You can disassemble the machine by following the steps mentioned below--
1. Remove the front panel (screws on each side)
2 Remove the two 3/8 screws pointing upward. This will allow you to lift the top up.
3. Remove the agitator.
4. Remove the spanner nut (requires tool and its left hand thread).
5. Remove the top off the outer tub (some snap off and some have a clamp all the way around the tub)
6. Remove inter tub.
7. Remove the set screws in the mounting stem (the treaded stem that the spanner nut was on).
8. Now with the same tool remove the mounting stem.
9. The outer tub is mounted to three legs. Remove the bolts that hold it on and remove the hoses from the tub. Once it is done remove the outer tub.
10. Remove the rubber boot.
11. Prop the tub up on something so that you won’t damage the stem that the drain hose connects to and step on the seal to push it out.
12. Turn the tub back over and install the new one the same way (may want to lube it with a small amount of soap).
13. On the transmission there is a metal sleeve where the tub sits, remove it. Now reinstall the new sleeve.
14. Reassemble the washer replacing the seal, boot, tub bearing, mounting stem and spanner nut.
This may help you--
Also check the Drain pump and drain hoses inside the washer if they are firmly connected and not leaking. You can see this diagram for more details--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Sep 20, 2009 | Amana Washing Machines
Kenmore 22622 Top Load Washer Logo
50 people viewed this question
Sal De
 Brian Main
Brian Main
