Question about Dell 16X DVD±RW Serial ATA Internal Drive for Optiplex 755 Energy Smart Desktop (TP969) DVD Drive
Configuring dell optiplex 755 sff
I am unable to get my 755 to recognize both the cd rom and the hard drive from the bios...it will recognize either unit just as long as the other is disconnect...both cd rom and drive are new..no os installed
  • waynerinke Apr 20, 2009
    no luck...sata drives.....tried hooking up a usb floppy.....won't recognize it either
  • waynerinke Apr 22, 2009
    I have an Optiplex 755 SFF that will not recognize both the dvd rom and the hard drive at the same time. These are both new SATA drives.. If I disconnect either, the other will be recognized.
    I have also bought a new USB floppy. It does not recognize either..
    I think it may be a bios problem but can’t update BIOS without some DRIVES.
    It will read the dvd and start to load windows, but when it is time to load to hard drive, it shows as drive not present..I am really stumped on this one.
    I have tried everything I can think of...Any help would be really appreciated..
  • 298 Answers
On the back of each device their should be a jumper on the right side next to where the ribbon cable plugs in. Remove the jumpers and replace them into the slot thats for "Cable Select" Their should be a picture on the top of the device if they aren't labeled. You can also put the jumper for 1 as "Master" and the other as "Slave"
Posted on Apr 20, 2009
  • Mike  Petrowsky
    Mike Petrowsky Apr 20, 2009
    ahh ok sata drives.. While installing windows you will need to provide the sata drivers on a floppy. you can use the internal or usb floppy drive. Go to dell.com and under support enter your service tag or model number and download the sata drivers. either unzip to the floppy drive or install the program and it will write to the floppy depending on what kind dell uses.
    While installing windows watch the bottom of the screen as soon as it starts it will prompt you to hit F6 to install additional drivers.
    Thats for XP, with vista it should detect them automatically.
  • Mike  Petrowsky
    Mike Petrowsky Apr 22, 2009
    One quick and easy solution is to replace the motherboard, if it is in fact found to be faulty.
    eBay 60-70$
    Have you contacted DELL Support? Is it still under Warranty?
Im unable to get windows vitsa to install in my optiplex 170 it wont read the disk but read the xp disk
Is the disk a DVD or CD? Does your Computer have a DVD rom? This little freeware program will help you ID your system: http://www.filehippo.com/download_speccy/
Dec 16, 2012 | Dell OptiPlex 170L PC Desktop
Numbers 3and 4 are lit on front of dell 755 nothing else comes on but fan
I was going to suggest that you have bad sectors on your hard drive that prevent you from booting, but since it won't boot from a CD either it sounds like you have a problem with your BIOS and possibly bad sectors on the HD as well. There's no simple way to fix this if that's the case, so it's best to be left up to a local pc repairman in your area...sorry
Aug 27, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
I have a dell 755 that the CD drive won't play certain CD's. It is not the CD because it plays on other machines. Some CD's will play just fine. Get's the error message Unable to Access Drive D tr
it depends on the files on the cd ...they might require a certain software to be installed in order to be read..for example the player may not be able to read mp4 without a codec installed ..or vcd (video cd ) to need a dvd player installed or a player that supports video cd and dvd-es..Same way for other file types...or ...certain speeds being imposed on writing ..and your cd drive to be unable to read them on those speeds..
Nov 09, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
Does a firmware update for dell optiplex 755 optical drive fix intermittent rebooting issue
dell 755 drivers page
your looking at the wrong firmware
optiplex 755 current bios version: A10 date 6/20/2008
for the CD Drive need to open device manager and check
what brand and model you have for dell used 2 DVD drives
b0a7e29.jpgsony and teac
use the correct firmware on drive, if not the drive will be killed.
if unsure open case and look for name/model on sticker of drive
Jun 23, 2009 | Dell Optiplex 755 Desktop Desktop Computer...
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Boot problem with Dell Optiplex GX150
To reinstall Xp from the CD you need to press F2 and go into the BIOS then select the boot order configuration and make the CD the first boot device and the hard disk the second boot device.
After installing XP, if you wish you can go back into the BIOS and change the boot order to boot from the hard disk first.
Dec 13, 2008 | Dell System Board for Optiplex GX 150,...
BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
Nov 17, 2008 | Dell OptiPlex GX270 PC Desktop
Dell 16X DVD±RW Serial ATA Internal Drive for Optiplex 755 Energy Smart Desktop (TP969) DVD Drive Logo
2,458 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
