Question about Emerson PD6870RD Radio/Cassette/CD Boombox
Pause button is stuck
Emerson model PD6870RD pause button got pushed in too far and is stuck. how can I release it.
    Genius:
  • 1,689 Answers
Hi soblessed,
the plastic push lock that holds the button is possibly broken, but hopefully the mechanism incorporated with the button has not been damaged because it was pushed too far.
to have this issue resolved, you may use something pointed to nudge the button from its place and free it from being stuck. Or you may remove the screws from the button, freeing the upper case from the lower case exposing the other side of the controls, so you can push the pause button out.
regards,
voodoo
Posted on Apr 20, 2009
  • FresnoJack Jul 14, 2011
    More detail would help, e.g.s., which tools that could be useful would help. Say, ice pick, needle nose pliers, etc.
Start/pause button will not release
Could be just dirty, e.g. fizzy drink or coffee spilt. Try cleaning with real care and detail around the edges of the switch, use a cocktail stick to get into the gaps.
Dec 07, 2013 | Washing Machines
The start/pause button has been pushed in too far and I would like to know can I fix this???
that happened to my machine once, I gently wiggled it whilst very quickly giving it a springy type push and it popped out again. if that doesn't work, Make sure your hands are DRY and UNPLUG the machine from elec remove lid and reach inside and release the spring.
Jan 03, 2013 | Washing Machines
How can I get a Manuel for Emerson model no. PD6870RD
I need the manuel for the Emerson PD6870RD I can not download it
will you please E-mail me the manuel. I don't want the add on's on
my computer. sholtysrb@comcast.net thank you so very much.
Betty Sholtys Longview, Washington 360-423-3269
Sep 05, 2011 | Emerson PD6870RD Radio/Cassette/CD Boombox
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Alpine cdm 7861 stuck in pause mode
Check for a "jammed" button. They use a little rubber membrane behind buttons and over time they do wear out. It is possible to push a button on the corner, make it shift enough to jam behind the faceplate & hard to see. Just push the button and see if it pops back like the rest of the buttons on the unit. If it still has a problem, post a comment and I will help you some more. Hope this helps
Jun 22, 2009 | Alpine CDM-7861 CD Player
Rca Universal remote RCR311W
Try with the philips this method:
Manually turn on the tv or the device to be controlled.
Push and hold the code search button until the red lights stand.Now release the button push and release the tv button,then you got to push and release the on off button until the device turn off stop push and release the enter button.
You might need to push the on off button 1 to 150 times.
Good luck
Aug 22, 2008 | Televison & Video
Television
Try this: turn on your tv.
Push and hold code search button until the led light stand.
Release him push and release the device button( Tv,Dvd,Vcr),now you got to push and release the power button until the tv turn off now you push and release the enter button and the code are now on the remote memory.Good luck
Aug 20, 2008 | Emerson EWF2704 TV
Tv stuck on video
Try with the channel up/down on the TV or look inside the configuration menu, if your set has one.
Feb 15, 2008 | Emerson EWF2004 20" TV
Magnavox DVD/VCR player stuck in progressive scan mode
Right, mine was stuck for a couple of weeks and i tried lots of different things. What worked for me was plugging it out and in again. Press the power switch and then just before the tv switches from normal mode to dvd recorder press the eject button. However, I pressed it a few time so not exactly sure which one worked.
The burned DVD is now in a thousand pieces at the bottom of my bin!
Good Luck!
Oct 20, 2007 | Emerson EWD2202 DVD Player/VCR
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Emerson PD6870RD Radio/Cassette/CD Boombox Logo
204 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
