Question about Char-Broil Grilling
I have a 2 year old 4 burner Iseries Char Broil Grill with side burner. It will not light. I tried different gas canisters and checked for spark from the igniter (there was). I wire brushed thegas jets. Nothing worked. What should I do?
  • tfishe02 May 09, 2009
    I found a regulator and hose at Sears for $25. I then looked at the grill to determine that the regulator/hose can be disconnected. While the hose appears to have a nut, the connection is up agianst a panel under the burner assembly and difficult to reach comfortably. I do not see how I can attach a pliers/wrench to the line and a wrench to the nut and get enough leverage to turn the nut. Any suggestions?
    Sergeant:
    Champion:
  • 219 Answers
Hi, well u better call a mechanic as he will be able to do it properly and it won't cost u much but if u try urself u can damage it.So go for a mechanic mate.
Thanks! Sandy
Posted on May 09, 2009
    Scholar:
  • 96 Answers
It sounds like your problem is probably the propane regulator. It's should be mounted on the inside of the frame near where you put the propane tank, and the hose for the tank will run into this. This part is a safety feature that will not allow flames to feed back into the tank, so do NOT by-pass. You should be able to find one at a reasonable price at your local major hardware store. Let me know if this helps :)
  • Richard Neely
    Richard Neely May 20, 2009
    hmmm... well, you could try to remove the cover and slide it down the hose far enough to reach the fitting easily, or loosen the mounts for the actual burner or valve that the hose attaches to and move them to a better position.
Char-Broil 463722313 chain
think its a match holder, if the spark doesnt work, you can place a match on it, light it and lower it down to ignite the gas...
hope this helps
Jan 04, 2014 | Char-Broil CharBroil 4637318 Grill
How to replace regulator/hose/valve assembly on char-broil gas grill?
Follow the hose back to where it connects to the gas rail , and go from there , to see what has to come off if anything .
Apr 21, 2013 | Grilling
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
I'm trying to replace the burner on a Char Broil Master grill 7000
Should be able to get the burner assembly at any Lowes or Home depot store and not hard to change out. Old one lifts out and new sits right in. Hope this helps.
Mar 19, 2010 | Char-Broil 7000 Quick Set Gas Grill
I can't get the grill to light....can you help me?
If you have 20lb gas tank, you could try opening the bottle really slowly. The newer tanks are equipped with a device called OPD, which means, overfill protection device, so when you take it to be refilled the filling station can't over fill it. However, if you open the tank too fast, it will cause this device to restrict the gas flow to the grill.
Nov 14, 2009 | Char-Broil Advantage 463453306
Char Broil grill w/full tank and cleaned air jets, no heat
try opening the tank really slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 17, 2009 | Uniflame FG2204C Grill
New Char Broil gas grill heating issue
Did the kit come with NG orifices and did you use them.
Jun 23, 2009 | Grilling
I have a char-broil 3 burner grill that is about 6 years old. It has 3 circular burners. The amount of gas now getting to the burners is equivalent to low even when the dials are on high. Do I have a...
most likely burner problem try removing burners (they generally just lift out or held by 1 or 2 screws) clean the sides of the burners with wire brush most likely then orifices on burners are clogged hope that works for you
Aug 23, 2008 | Char-Broil CharBroil 4637318 Grill
Grilling Logo
42 people viewed this question
Top Char-Broil Grilling Experts
paulcarew
Dean Gruber
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
