Flat screen is going out
Envision 7400e just started blanking out. Upon windows opening, right clicking on graphic options and switching from lap top to monitor, the monitor lights up for approx. 2 to 3 sec. then blacks out. Through process of deduction, I replaced vidieo cord and no solution. Then I hooked new cale to another lap top, thnking video card in my laptop could be going out. Again, no solution. Obviously, it is the montior. So any ideas what might be happening with monitor? Thanks for any ideas.
  • Art Ellison
    Art Ellison May 11, 2010
    Does the laptop screen work OK?
    If so, and the monitor won't stay working, then it is bad, probably.
    One thing I would do is check it with a second external monitor.
    Novelist:
  • 177 Answers
Replace the VGA or HDMI (whichever you're using) Cable, and the Power Cable (one of the two can cause this problem, or even worse, fry it!)
Then,...... try connecting the monitor (with new video and power cables to another pc that you know for a fact is working correctly... the problem could be your power supply, motherboard, etc..
If that doesn't work.....Return The Monitor if you can..........cuz if the above doesnt fix your problem, ........then you'll know the monitor is bad......but don't assume that til you try my solution k!
Posted on Apr 20, 2009
How do i get my lap top screen to fill whole screen top to bottom
right click desktop then graphics option then panel fit then full screen or aspect ratio which ever you prefer
Mar 05, 2015 | Toshiba Computers & Internet
I have a screen flickering problem on my hp pavilion dv4-1120us.how do I fix it?
Try to use Display options to change the refresh rate. If you're on 60 Hz, you might want to change to 71 Hz or something different from where it is currently set.
Depending upon which version of Windows you are using, you get there by right-clicking on a blank spot on the desktop, and choosing Graphics options or Screen Resolution, then looking for the setting for refresh rate.
-a.
Jun 24, 2012 | Computers & Internet
Is it free: My monitor goes to sleep. How do I stop this?
Right click on power options and remove the sleep option.
Hope that helps.
Jan 22, 2011 | HP Computers & Internet
I have an Envision EN 7100s monitor. It works just fine when I run the computer in safe mode, but when I try to start the computer normally the screen will go blank after the microsoft logo and say "Input...
Doesn't really sound like the monitor is the cause. The video driver sounds like it might be failing on load. You can try starting in safe mode, open device manager and remove the video card from the hardware list (You can also do this with add and remove hardware in the control panel of XP). Restart and let windows install fresh drivers on start up. This may help if the driver installation has been corrupted. Note that you will need the original driver disk if you want the extended options of your video card, otherwise windows will install the generic windows driver which in some cases is no different from the factory driver.
Hope this helps,
Gill
Oct 07, 2010 | MPC Computers Envision EN 7100s 17 in....
Using two monitors attached to my lap top and can only use one of the two screen
  • Attach two monitor and switch on the laptop
  • automatically second monitor will show diplay
  • if not then find out dual display symbol on the taskbar click on it.
  • window will open select dual monitor
  • click apply
  • if not then right click on desktop --properties--desktop two monitors symbol will see select 2nd monitor
Apr 17, 2010 | E-Machines eMachines Monitor E15T4
I used The FN and F5 key and it worked
Go to the point where you have a stable picture even if it is huge. Right click on an empty space on the desktop and scroll down to properties. Click on settings and increase the resolution a little at a time hitting apply and checking the display as you go. Keep hitting ok to the display settings if you like them. Find the resolution and display size that suites you.
Sep 07, 2009 | Acer Aspire 5500 5570-2609 Laptop
Black on two sides of monitor
For the Start menu, I assume you're talking about the taskbar that appears on the bottom of the screen. Press the Windows button on the keyboard (usually located between the Ctrl and Alt button on the left hand side).Right-click on the Start button. Click on the Taskbar tab and check the box that says "Lock the taskbar". Your taskbar should return to your desktop.
Wallpaper (desktop image)
In XP:
Right click on a blank space anywhere on the desktop. Click on graphics properties. You should see a window with your Wallpaper previewed in the top window. Click in the Settings. There should be a setting for "Stretch". Select Stretch and your desktop should return to normal.
In Vista: Right click on a blank space on the desktop, click personalize/display settings/advanced settings Click on your graphics card if available or graphics properties. You're looking for Aspect Ratio options From here you will see a setting with 2 options
  1. Maintain aspect ratio
  2. Full screen (no border)
Depending on your graphics card, this process may differ slightly, but the setting you need is Aspect Ratio
I hope this answers your questions. Best of luck.
Greg
Jun 15, 2009 | Compaq (388110-001) Pentium III, 450 MHz...
My screen has "out of range" written across the screen.
if you have another monitor available .. try using it to reset you refresh rate for the graphics card.. this is usually because certain monitors only accept certain frequencies
Jan 09, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Envision LCD monitor: ''Auto Config Please Wait'' is always on
Just tell me why this message comes up and if it means my monitor is going
Dec 21, 2008 | MPC Computers Envision EN 5100e 15" Flat...
Resolution change on my lap top screen when I load my webcam
I had this problem on my PC and I tried everything from updating drivers to re installing the software and updating my graphics card but nothing seemed to work.
And then as a last resort I right clicked on the icon on my desktop and chose properties and clicked on the Compatability tab and unchecked on display settings Run in 640x480 screen resolution.
This worked and did not affect the webcam in anyway.
Feb 16, 2007 | Acer TravelMate 4672WLMi Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
