I tunes library problem 1035 error and can't save library
Cannot open my i tunes
https://www.youtube.com/watch?v=U-p5HTZpWm4
Feb 10, 2014 | Revision Goggles Exoshield Extreme Low...
Ricoh 1035 error sc 818
hi
this error happened when :
Incorrect Function DIMM installed in Slot #2 on Controller PCB. (Slot #2 is for PostScript Option only) so you can:
Reload System Firmware.
Replace Controller PCB
for fix that.
Oct 25, 2012 | Ricoh Aficio 1035 Copier
I don't know how to save all my i-mac music into the Seagte hard drive? I've followed the instruction few times and download the software, but I just don't don't know how to save my i-tunes music into the...
open up Itunes in the top left hand corner select file from the drop down list select library then you will have options toback up to disc organise library export library import playlist and export playlist
hope this helps
Mar 22, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dont have internet on my computer im at the library on a computer i need to no how to get a patch for tunes 3.0 i get meesage error on my computer need to get update
here's the patch that you're looking for, here. as for getting it to your computer without internet access and only using the library's computer, you would need someplace to save the program to. such as a flash drive or a disc or something for you to save the file to. that's about all i can think about for your options without an internet access.
Jan 04, 2011 | Broderbund TunePlus for Apple iPod Full...
When i want to save a tuning in absynth 5 it says : 'store library module failed' and I cannot save my tunings, any ideas??
I just recently had the same issue and found a way to resolve it.
- Go to the directory where your "tuning" folder should be and make sure it is there, or add it:Library>Application Support>Native Instruments>Absynth 5>Libraries>Tuning
- Open Absynth 5 in standalone mode (by navigating to the app and opening it)- Go to "Preferences" in the Menu- On the "general" tab in absynth prefs there is a "TemplateLibrariesDirectory", click "browse"- Point it to the new "Tuning" folder you created and voila! -Now you can save and access saved tunings...
BONUS:
Best to you!Charlie Graham
Feb 17, 2010 | Native Instruments ABSYNTH 4 Full Version...
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
How do i set aficio 1035 to factory default
SC352 Indicates ID Sensor/Pattern edge detect Error 3. If its a color machine, then it's a Magenta TD ensor failure.
Usually If you need to change the developer roller you should change the developer as well. Once that is done, then you go into service mode and calibrate the developer and initialize the TD sensor.
Did you change the developer?
Aug 02, 2008 | Ricoh Aficio 1035 Copier
Ricoh 1035
It says communication error to control panel at station.
Turn the copier off, wait 30 seconds, and turn it back on again.
It should go away. If it doesn't a technician needs to come out and look at the problem.
Jul 31, 2008 | Ricoh Aficio 1035 Copier
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
