No sound from OLEVIA TV
I have had this tv for 1 year and recently noticed sound from the speakers was starting to go on and off. now its completely off. I am able to get sound only through the home theatre only.
  • 93 Answers
SOURCE: home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Posted on Oct 04, 2007
SOURCE: Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Posted on Dec 24, 2007
SOURCE: Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Posted on Dec 29, 2007
  • 7 Answers
SOURCE: Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Posted on Jan 27, 2008
harishu
  • 18 Answers
SOURCE: no sound comes out of my home theatre hen i plug it on my tv
hello
use the link below to check out if this is your tv. http://www.p4c.philips.com/files/2/29pt4273_75r/29pt4273_75r_dfu_eng.pdf
if it is, then go to page 5 in the manual.
connect L/R from monitor out to the AUX of your amplifier. when you want sound from the tv, select AUX as source from the front panel of your amp.
hope this helps
Posted on May 27, 2008
The audio on my Olevia 42 inch screen flatscreen TV is echoing on every channel. Any ideas how to make it stop?
try external speakers and see if it continues, if yes, need new tv, if no, then use external speakers. (you also can try unplugging from power completely and see if that resets it).
Apr 30, 2016 | Olevia Televison & Video
Sound quit on Olevia SyntaxBrillian 232-S12
A common symptom of power supply trouble is disappearing sound
Apr 01, 2013 | Olevia Televison & Video
I need the product specifications for this model
hi,
u didn't specify any model. any how i am senting speck of the following model. if u have selected model in ur mind, just contact me through fixya. will sent u the specification.
dotclear.gif Olevia 232V General
  • Product type LCD TV
  • Diagonal size 32.0 in
  • Viewing angle 178 degrees
  • Viewing angle (vertical) 178 degrees
Video
  • Technology TFT active matrix
  • Resolution 1366 x 768
  • Display format 720p
  • Image aspect ratio 16:9
  • Pixel response time 8.0 ms
  • Progressive Scan Progressive scanning (line doubling)
  • Widescreen Widescreen
  • Widescreen modes Panorama,
    Full,
    Conventional 4:3,
    Zoom
  • Dynamic contrast ratio 1600:1
  • Comb filter 3D digital
  • Color temperature control Yes
  • HDCP compatible Yes
  • Supported DTV resolutions 1080i,
    720p,
    480i,
    480p
  • Supported computer resolutions 1360 x 768
TV Tuner
  • TV tuner presence Yes
  • Tuner qty 1x analog/digital combo
  • Digital TV tuner ATSC
  • Analog TV tuner NTSC
  • Secondary audio program (SAP) Yes
Audio
  • Sound output mode Stereo
  • Total output power 20.0 Watt
  • Speakers 2 speakers
  • Speaker system speaker type Right/left channel speaker
  • Additional features Auto volume adjustment
  • Speaker form factor Built-in
  • RMS output power 10.0 Watt
  • Speaker system speaker qty 2.0
  • Audio controls Bass,
    Treble,
    Balance
Convenience Features
  • Closed captioning Yes
  • Parental channel lock Yes
  • V-chip control Yes
Connectivity
  • Video interface S-Video,
    Composite,
    Component,
    HDMI
  • HDMI ports qty 1.0
  • PC interface VGA (HD-15)
Remote Control
  • Type Remote control - Infrared
Power
  • Power device Power supply - Internal
  • Power consumption operational 180.0 Watt
Dimensions & Weight
  • Dimensions (WxDxH) 37.8 in x 9.4 in x 22.2 in
  • Weight 35.5 lbs
Manufacturer Warranty
  • Service & support 1 year warranty
  • Service & support details Limited warranty - Parts and labor - 1 year
Dimensions & Weight (Shipping)
  • Width (Shipping) 42.8 in
  • Depth (Shipping) 12.4 in
  • Height (Shipping) 25.4 in
  • Weight (Shipping) 45.4 lbs
Sustainability
  • ENERGY STAR Qualified Yes
Dec 14, 2010 | Olevia Televison & Video
I tryed to connect coby speaker (model number - csp42) up to my olevia 337-b11 tv and i can only hear sound through the bulit in speakers in the front of the tv and not out of the coby speaker! the coby...
Does your TV have an Audio out? This is the only way that you can get signal to feed to your coby speakers and make sure that your coby speakers has an amplifier.
Apr 03, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Olevia tv
try unpluging, wait about 30 seconds and plug back in.
Mar 23, 2009 | Olevia LT32HVE 32 in. LCD Television
Blue power light is on but tv will not come on olevia 237T11
I know this post was a while ago, but I stumbled upon a solution to my tv just recently. I don't know if this will work for everyone's tv, but I find it hard to believe that this would only fix my tv with the same issue.
I opened up my tv and found that the placement for the connection for the power cord is poorly designed. For one it is very loose. Two, I don't know much about circuit boards but the connector has 5 prongs. Two of which are part of the same piece to both, I think, to anchor it down and ground it (it looks like it's part of the actual ground wire.) and the other three which I assume power the board. Those three are not completely soldered on completely e.g. they have holes in the soldering. The last thing I noticed is the ground wire is crossing the board and touching one of the coils.
As my tv got worse it started making a "short" sound. When I opened it up, I removed the connector and insulated the wire more. Also, I anchored it down tighter using the two prong piece (just made it tighter by pushing it down more and folding the prongs against the board and soldering it). Last, I re-soldered the 3 prongs, completely covering them. Put the tv back together and viola...it came back on and no problems.
I hope this help and I hope this makes it around to all the people who have this tv. It"s not a bad tv just a poorly designed board.
-Falchemist
Feb 18, 2009 | Olevia 237T 37 in. LCD TV
Crackling noise
I think I have solved the problem. I dusted the tv completely. Then took the cable box and with a hair dryer in the cool setting blew out the interior circuits to try to remove all dust. Turned the set on no more crackling. Thanks for the posting.
Nov 14, 2008 | Olevia LT37HV 37 in. HD-Ready LCD...
Olevia 337 B11 Power Problem
Olevia sugested repl. the Main board
Mar 05, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 32" LCD HD TV model 232-S13
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Jan 12, 2008 | Olevia LT32HVE 32 in. LCD Television
SHARP,PIERCING, ALARM LIKE NOISE COMING FROM TV
unhhok all the sources from the tv as to eliminate where it might be coming from, hook up one source at a time you might find the problem that way
Oct 20, 2006 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
Electro Med Services...
