Question about Daewoo Televison & Video
Relay clicks, but No sound, No picture.
Re: Sony TV, Model #KV-32HS510, Chassis #DA4
When power button is pushed, relay clicks, standby light flashes six times, after a few moments of non flashing, light again flashes six times, and keeps repeating this.
Check voltages on different components in power supply, voltages would check normal, and then collapse when relay drops out.
Any help would be greatly appreciated
  • 700 Answers
Hello, just try this first.
Unplugged the unit the power outlet for about 60 sec.Then power it on again. If you have surge strip along the line. You should directly switch in on power outlet only. If this doesn't help.
As the relay is working you have power in standby mode. Check its supply voltages if its ok. Secondly you can check the the B+ supply it is in DC, If this is a crt type tv, check its horizontal output transistor, Check its flyback for short circuit. Capacitor near to it rated almost 800V, and deflection coil.
Just for input, hope it helps
Posted on Apr 20, 2009
I have a Sony FD Trinitron Wega (KV-32HS510). When I attempt to turn the tv on by pressing the power button on the remote or on the tv, the standby light comes on and I hear two clicks but tv don't...
The primary power supply is good,maybe the horizontal output transistor is deffective thats why there is no high voltage supply in the picture tube because theflyback have no supply voltage and oscilation.So check the harizontal output transistor and replace if deffective.
Sep 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
Tv shuts itself off randomly
hi
you have defective power oscillation in power section
this needs to diagnose for a qualified technician
Thanks!
Feb 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Jan 07, 2009 | Sony KV-27S46 27" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony kv-27s42 no picture no sound can here relay click
I will look up your specific model to be sure, but teh 3 blinks usually mean a power supply problem. Stay tuned for more...
Dan
Aug 23, 2008 | Sony KV-27S42 27" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
249 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
