Need tv code for a Spectra SS213 TV (Strawberry Shortcake) Just had Dish Network installed. I would like to turn the Strawberry Shortcake tv on and off
    New Friend:
  • 56 Answers
Codes are hard to come by for this brad as it more than likley is s a sub brand for a major mfg. however you can take your dish remoter and use a powerscan to find a correct code. do this by holding down the SAT button till all lights light up at the top, then enter the code 500 then press pound, Now press the SAT again till they light up then release, then press teh big red power buton once, then press teh blue up arrow onece every 2 seconds until you tv shuts off, ( dont go to fast or you will pass up code. as soon as your tv shuts off, press the pound key and your ready to go with power and volume.
Posted on Nov 12, 2009
SOURCE:
Codes for tv remote for dish
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Dish TV remote control code list is given.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 16, 2014 | DISH Network Televison & Video
Restart ss-2250 strawberry shortcake dvd player after prog. scan snafu
You should be able to simply shut the unit off, & turn it back on after a few minutes. This will reboot the player & it should perform normally. If this fails, look for a tiny reset switch somewhere on the unit. It will be marked, but may be a tiny hole with very small lettering, that requires a pencil point to activate.
Jul 09, 2007 | Spectra Strawberry Shortcake DVD Player
Programme remote to work with sony tv
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
-Kirstie DISH Network
Sep 16, 2010 | DISH Network IR Remote Control
I am looking for a remote or a replacement for my
Try website 1-800-Remotes Factory Original.Buy a exact or very close.
Feb 07, 2010 | Spectra SS213 TV
When dvd is inserted the player starts clicking & it doesn't want to eject the disc.
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! Unplugg before opening!
Oct 12, 2009 | Spectra Strawberry Shortcake DVD Player
No cable channels are working with the TV Spectra SS213 TV
goto the menu and make sure it is set to cable and not to off air or local setting. after setting to cable, run an auto scan to lock in available channelss
Oct 06, 2009 | Spectra (SS213) 13 in. Portable Television
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Univseral Remote Code for SS213 TV
I don't think there is a Direct TV remote code for this type of television. (Strawberry Shortcake). I'm assuming the reason is because this is such a cheap, generic tv that Direct doesn't recognize it. "Strawberry Shortcake" isn't as big as "Hello Kitty" I guess.
. This is sad because even though the big, pink power button has popped off to where you have to press the little rubber nub, my daughter has been using hers for well over two years where many reviewers have given the tv model bad reviews of breaking down after only 6 months. Hers did not come with a DVD player, although it IS a SS213 model.
May 07, 2008 | Spectra SS213 TV
Strawberru shortcake tv turns on then right back off
Sounds like the power supply may be going out, or check and see if there is a circuit breaker button on the back. Otherwise there may e a blown fuse that is internal. Don't open the back unless you have training on what is safe to touch as the picture tube can maintain a HUGE electrical charge that can stop your heart if you accidently touch the wrong thing. Sounds like a weak power supply tho. Jay
Jan 15, 2008 | Spectra (SS213) 13 in. Portable Television
Not Receiving Cable Signals
100% you have or a faulty tuner inside that has to be checked for dry joints or it has to changed completely. Patrick
Aug 26, 2007 | Spectra SS213 TV
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
Ekse
