Question about LG LRM1260SW Microwave Oven
Does not heat up any more.
Microwave does not heat up any more. All other electricals work ok.
  • Anonymous Apr 30, 2009
    had the microwave for 3 months and it stoped heating up food.
  • 3,037 Answers
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
Should i keep the capacitor installed in the microwave before testing? Should i plug the microwave to electricity. Before testing?
If you are testing the capacitor, it needs to be out of the circut. Be aware that a cap can retain voltage after the power has been unhooked.
Jan 06, 2015 | In Microwave Ovens
JVM16331BB005 over the range microwave oven will not heat everything else works ok
That is a sign the magnetron has shorted and is the most expensive part to replace.
Apr 28, 2012 | GE Microwave Ovens
Does not heat food-master relay reset, all electric OK (fan runs, time & all other settings show OK, turntable rotates), door closed tightly, control lock
THere are three possibilities, open magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor.
Mar 14, 2012 | Maytag MMV1164WB Microwave Oven
Don't heat consistantly micro or conv--sympthems-- no oven light no heat --occasionally ok--- ser. #113806
Hello there,
The problem could be from the power diode. A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Also a capacitor could be faulty. A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating or working intermittently. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Finally, the magnetron could be faulty. A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
You will have to test them and replace the faulty component amongst the three factors.
Hope this helped.
All the best.
Elect_Comp
Oct 31, 2011 | Sharp R-1870 Convection/Microwave Oven
When press START microwave timer starts but will not heat?
Your door safety interlock switches are the primary candidate for this problem. The oven thinks the door is open because one or both of the switches are faulty or out of alignment. When the door is open, NO HEAT. Check em out.
Jun 09, 2011 | General Electric Microwave Oven
Microwave won't heat, light ,clock works the microwave just won't heat the items in it.
hELLO THERE
when a microwave quits heating but every thing else is ok normally
investigate these 4 areas
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
microwave_diode.jpg Power Diode
picturena.gif High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
microwave_magnetron.jpg Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating
it can be saved but get a quote from the shop first before proceeding and always evaluate it against the cost of a new one,
it could be the power supply has shorted but check it out.
Jul 29, 2010 | Daewoo KOG-867T Microwave Oven
GE Spacemaker Microwave #JVM1650WB008 is not heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Doesn't heat
If the microwave is working ok, it should heat up. First check the fuse inside if it ok then it looks like your microwave generator has gone bad. You will have to take it to the vendor and have it fixed with warranty.
May 17, 2008 | Sharp R-510HW Microwave Oven
Used tefle coated tin micro+convection oven
There are some times when it is ok to use metallic stuff in a microwave. This is probably one of them. But you won't get the manufacturer to agree. Metal concentrates the microwave energy making a strong enough local electric field to cause sparks and heat. Usually burns that spot. Do you have one of those popcorn cookers for microwaves? Works by heating a special pad in the bottom just right.
What the manufacturer is saying in the warning is:
Don't sue us if you use metal in this oven and something goes wrong.
Feb 07, 2008 | Microwave Ovens
LG LRM1260SW Microwave Oven Logo
363 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
