Power problem When power button is pressed the fan for the power supply starts up but nothing else happens. Holding in power button does not cause shutdown. CPU fan starts up when power cord is removed from power supply.
  • 4 more comments
  • Anonymous Jun 01, 2008
    power supply fan jam
  • raww Dec 07, 2008
    I may have the same problem. I push the power button and it soulds like a car with a bad battery. It will not power up and as soon as I let go of the power button it just shuts down
  • Anonymous Dec 13, 2008
    I have the same issue. Power but no post. It seems to be the processor or motherboard but i don't know witch one.
  • Anonymous Jan 07, 2009
    hey everybody i got Pc hpcompad d500 minitower he dosen't start the the power sign still red and clignote i chk the memory but always the seems problem i'm affraid that's the MotherBoard is out of time to life
  • shanthi2522 Apr 07, 2009
    power not on
  • Anonymous Mar 27, 2014
    I'm getting power to the power supply. I can tell cause the light stays a steady green. The pc won't power up when pressing the power button. Nothing happens at all. What can be done to solve this issue?
I have a emachine w6409 fans will run but that is all w i push button
Posted on Jan 28, 2009
    Sergeant:
    Champion:
  • 293 Answers
NO POWER Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective. SWITCH PROBLEMS A trick can be done here. Unplug it then spray the switch (Soaked) with warm distilled water with mild soap. then let it dry using a Hair Dryer. Then test! If failed, Replace the switch. If Persists then There is a problem with the Main Board or Power Driver. FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 20, 2007
SOURCE:
Computer not powering up
bad power supply. just replace
Jun 07, 2012 | Computers & Internet
No power to my desktop computer HP A1330N and no green light in the back of the power supply
You replaced power supply and your made sure you plugged everything back into the motherboard snuggly and in it's proper place? If so it might be your motherboard is bad.
Make sure you have the new power supply turned on. Sometimes there's a O/I switch on the back of the power supply. Flip it and try to boot and see what happens. You might have another bad power supply.
If so your motherboard might be burning them out.
Try removing the power cord for 30 seconds and press and hold the power button. After 30 seconds put the power cord back in and press the power button to see what happens.
Do your fans work when you press the power button? Do you hear any fans running?
Mar 23, 2012 | Computers & Internet
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
I have the same problem with 3 motherboards ML350 G4: I connect de powersupply to the backplane, all the fans starts, the row of leds on the mobo begins the check secuence with green status but ends with...
Have you already connected both power jacks to your board? It's motherboard needs two supply of power. One is near the cpu fan and the other is at the right side end. Check also if the power supply has the same value as your power outlet. Low voltage can still cause this king of problem. 220 Volts - 220 Volts, 110 Volts - 110 Volts. Hope this could help a little friend. Have a nice day.
Aug 20, 2011 | Compaq 365062-001 - System Board ML350 G4...
Computer turn on, but when it does it won't POST
It seems like a motherboard issue. It heats up, thus is not able to turn on continuously. You may need to check internal parts embeded on the motherboard llike the fan and processor before you could know what needs replacement.
Jul 18, 2010 | Dell Dimension E521 PC Desktop
When pressing the power button, the fans only come on. I checked all the connections, and tapped the power button, the fan can on briefly then it booted up. Why do this happen, and how can I prevent it...
There are a number of causes but the most likely cause is a faulty power supply. Try a different power cable to the power supply first, then try a different power supply to see if this solves the problem.
Let me know if I can be of any further assistance.
Best wishes,
Graemevm
Mar 04, 2010 | Lenovo IdeaCentre K210 Intel Desktop...
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Hi. my CPU (system) does not start. When i press the power button, the light turns on for a second then nothing happens.
Does the power supply fan spin when you switch it on ??
Do you hear a"posting" beep??
Does the CPU fan start to spin??
If no to all of these probably dud mobo.
Dec 21, 2009 | Intel CPU
1 - Dell HP-P2507FW - Intermittent on - off power at start-up
the only solution to your problem is replace the power supply.you have to purchase the same unit specs.
Nov 30, 2009 | Dell HP-P2507FW Power Supply ** FREE...
What does No Power/No POST Troubleshooting mean
Hi.
It refers to two symptoms. No power just means the machine is dead and nothing happens when you press the power button on the computer. POST stands for Power On Self Test. This is what happens just after you press the power button - the computer checks devices connected to it then starts to load Windows or whatever operating system you have. If the computer is dead, then it is often caused by a faulty power supply (metal box where the power cord goes in. If it won't POST then an error may be displayed to tell you where it stopped during POST, or error beeps may sound to tell the technician which part of POST has failed. Sometimes, you may hear the fans and hard disk, but the monitor stays dead. This is usually caused by the RAM coming loose in it's socket or the video card coming loose/ failing.
Mark
Jan 22, 2009 | Computers & Internet
Open Questions:
Computers & Internet Logo
554 people viewed this question
Ekse
Alun Cox
