Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Refrigerator not cooling
I have a Hotpoint side by side refrigerator, model # HSS25IFMB ww, and the refrigerator is not cooling well. I have it turned all the way up to see if it will help but hasn't. It keeps the food and drinks a little cool, but not cold. I cleaned underneath and in the back to remove the dust, but that did not help either. Any suggestions?i have the same problem, the refrig is a little cool, but not cold, the same is for the freezer, it is cool but not freezing anything. i havent really gotten to check for any issues, i dont really know what to check. any help?
  • Hotpoint Master
  • 19,396 Answers
Check the evaporator system. When defrost system (evap.) is not working fine , you get poor cooling cooling.
Check if fan is running fan is part 610 on diagram below.
MOTOR DC EVAP FAN (MOTOR EVAP DC)
THERMOSTAT DEFROST (THERMOSTAT DEF) Part 240 on diagram:
SENSOR TEMP - part 241.
If the evaporator is working , it can be the condenser, if the compressor is working a lot and there is not enough cooling, and evap is OK, then it is usually the condenser going under stress. Clean the coil at the back and leave some airy space at the back of the fridge.
Here the diagram
Posted on Apr 19, 2009
Hotpoint HSS25GFPA WW Freezer not cooling
check for ice build up on evap coils ,,, bad efrost cycle
Oct 05, 2014 | GE Refrigerators
After a moving to a new city, we had our Hotpoint model HSS251FMD WW refrig in storage for 4 months. When I installed it in our new house it will not cool. Is there a reset button?
flush the refrigerant by nitrogen & refile new refrigerant.every work doing by qualified technician.my be some compressor oil over com in freezer
Jan 03, 2011 | Hotpoint Refrigerators
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
I HAVE A wailing HOTPOINT HSS25GFPH WW refrigerator
change the rubber isolating washers on the pump and compessor too hard a compound will make things worse ,neoprene works best ......
Feb 07, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer and fridge are not cooling but we hear the sound of the refrigerator
your defrost heater or timer is not working . rotate you defrost timer until it clicks and check if its is defrosting if it is let it defrost for about 10 mins and turn the timer some more to take it out of defrost. replace timer
Jun 02, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25IFMB WW will not defrost.
I was having the same problem. I replaced my defrost heater (2 screws and 17 dollars) and it works great now
Mar 09, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Check in the freezer section by removing the food exposing the rear inside panel. DO you see frost beginning to build upon the rear inside panel of your freezer section? If so, the is a simple defrost problem and can be repaired easily. For testing purpose, st both control to the middle setting and do not move them during the entire testing period. Moving the controls only makes things worse.... Let me know what you find....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Sep 24, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
132 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
