Question about Toshiba Satellite A305-S6863 Laptop
My screen all of a sudden is green, grainy, and has black shadows! It was coming and going apparently unrelated to any action of mine. why?
  • ERIC BAKER May 11, 2010
    Have you tried starting up in safe mode to trouble the display problem's?
Sony bdps360 grainy picture issues
Unfortuneately the problem is in the RF circuits after the laser,but combined in the whole assembly. There is nothing you can do, except if warranty applies take it back.
Mar 13, 2012 | Sony BDP-S360 DVD Player
Pictures come out very grainy
Most likely, you've set the ISO value higher than necessary for most circumstances. You may have done this deliberately to catch some fast action, or you accidentally hit the ISO button without realizing it. If you reset to lower ISO settings, your graininess problem will probably disappear.
The faster the "film speed", whether you're using real film or a digital camera, the more grainy the pictures will be. ISO is the film speed. The ISO speed is set by pressing the ISO button (just above the "FUNC SET" button); it cycles thru AUTO, HI, 80,100, 200, 400, 800, 1600, then back to AUTO. If you've set the camera to AUTO on the control wheel opn the top of the camera, then you can only select ISO of AUTO or HI (which is slightly faster than AUTO).
The higher ISO settings are useful in low light conditions or to catch fast action, but those higher settings should not be used otherwise because of the increased graininess.
I hope this helps you.
Oct 19, 2008 | Canon PowerShot A540 Digital Camera
The screen is not clear
Grainy image = playing standard 480 cable or antenna on a high definition set
Double image - convergence ic's, or circuit
Green shadows - green crt coolant/tube issue
Since i haven't heard back, i'm going to clear this from my queue
May 23, 2008 | RCA Televison & Video
Monitor went black
Same with mine a couple days ago. I've been told the contacts have oxidized and need to be cleaned. It was going to cost about $80 to fix and no guarantee how long it would last so I just bought a new monitor.
Jan 04, 2008 | Dell E173FP 17" LCD Monitor
RCA input suddenly changed to black and white.
Mine is doing the same thing. I have a 2 year old RCA 27" and I was told to do a "hard reset" I am trying it right now. All you have to do is unplug the power cord to the TV for 4 hours. See if that will help.
Sep 22, 2007 | Akai LCT2785TA 27 in. LCD Television
Mitsu. 1080 Problem -- Green squiggly lines
if no one answered then hear my thoughts.  odds are it is 2 ic's
I say that because that has been the problem with mine,
except it was the red.  it happened in 2000 when I bought the tv
and just now.  its going to cost me about 400.00 to have someone fix it.  I'm getting it fixed because it's been good to me. I watch dvd's vhs's and laser disks and feel it has plenty of life in it.
good luck
Mar 02, 2007 | Mitsubishi WT-46807 46" Rear Projection...
LG RU-44SZ51D Ragged Black Stripe down Left Side of Screen and Grainy Picture
i came looking for a solution to the same prob but on the right side of the screen, i did take out the lamp which is on the right (looking at it) you need to undo two screws on the case and two on the unit and just pull it out, and i found quite a bit of ash there,almost like ciggy ash, i cleaned it out but problem is still there, so if i find a solution i will repost and would like to hear from you if you find one many thanks adders
Sep 03, 2006 | LG RU-44SZ51D 44" Rear Projection...
Toshiba Satellite A305-S6863 Laptop Logo
162 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
