Question about Maytag Neptune MAH6500A Front Load Washer
FL message my maytag washer fails to start and I get a FL message
  • 30 Answers
Is it leveled properly? Is the door latched all the way? Is the water turned on at the valve? Unplug the unit for a few minutes and during that time, unhook all in/out valves and make sure drain hose is in proper position and down in to the drain hole far enough. Plug unit back in and try that.
Posted on May 03, 2009
Maytag neptune washer code FL and DO
FL means the door failed to lock
DO
means washer door is sensed as being open.
Aug 19, 2016 | Maytag Washing Machines
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
I'm getting an "FL" message.
FL - Failed to Lock
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
You can get it at a local appliance parts dealer near you or online and to replace it you will need to open the door, remove the screws that run though the hinges into the cabinet and the ones straight across on other side, pop the top of the front panel loose and take off, remove the screw at the top of each side and raise the top panel and swap it out; check this DIAGRAM PARTS LOCATION
Hope this helps.
Aug 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag netune front loader washer- 10 years old. It is giving me an message FL when I go to start it. I can turn it off and try again and it will work fine. Am I headed for bigger problem?
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
  • faulty door lock solenoid
  • loose wire connection
  • faulty door lock switch
  • faulty door lock sense switch
  • bad control board
Here is a link to the manual for your machine also.
Jul 27, 2011 | Maytag Washing Machines
The Timer Window shows FL and the washer stops after filling.
I unplugged the washer for 20 minutes, plugged it back in, the same FL message appeared, so I slammed the door (as a last effort to attempt to overcome the problem of door failing to close before I would decide to call a repairperson). Following the sound slamming of the door, the washer has worked just fine through the last five loads.
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
FLASHIN FL SIGNAL
FL: THE WASHER FAILED TO LOCK THE DOOR
Check whether there is any object blocking the door or is the door locked properly when the wash cycle begins.Please do post further comments on this problem if it persists.Good luck.and please do rate my answer.
Jan 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Error code FL
FL means the door Locking Mechanism has failed. It will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2008 | Washing Machines
Maytag Neptune MAH6500A Front Load Washer Logo
69 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
