Question about Samsung RS2630SH Side by Side Refrigerator
Fridge temp will not drop to set temp - Samsung RS2630SH Side by Side Refrigerator
If you have had a sudden power failure or power spike, you may need to reset the fridge. This can be done by holding down the power freeze button and the fridge temp button together for about 5 seconds. The fridge display will go blank. press the buttons together again, the fridge display should return and both fridge and freezer should be reset
Posted on May 12, 2009
Stumped by Damper Control malfunction symptoms
U seem to have a good handle on things but the flapper door is still not operating properly. Rather than create more agita for yourself, you just might want to consider replacing the assembly if not that expensive. OR experiment with various flapper door openings till you get a more reasonable refrig temp since 25 is too low. Aim for 35 - 38 degrees.
Sep 01, 2015 | Refrigerators
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Fridge temperature shown is +14. Unsure how to set temp to say +6
Usually the model number and info is on a sticker on the back of the fridge , you will more than sertainly have to move your fridge to find this info.
Feb 08, 2013 | Refrigerators
I have just bought a new Samsung Fridge and have plugged in and set the temperature controls for both the fridge and freezer, but it is not getting cold. What is wrong?
First make sure the unit has at least two inches of clearance in the rear.
Also this is a rather large piece.. at least ten cubic feet larger than the average fridge. It should take about 3 - 4 hours to get to the desired temps. It will take about an hour for it to begin to get cold ..and 3 - 4 more to drop to where it will be ready.
If you filled it with anything warm..or room temp.. add more time.
I scanned the owners manual..it does have a power cool setting.. but it is probably best to just give it a few hours.
Best of luck!
May 12, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
I have a Liebherr fridge which seems to be on permanent supercooling. It freezes fluids. I try setting a higher temperature but it just drops back to 4 C
4c is the std operating temp for most fridges.have you checked the door seals for fit if an airleak occurs fridge will try to maintain cooling.....freezing salads.
Feb 11, 2010 | Refrigerators
Freezer set to 0 actual temp - 1 Refrig side set to 37 actual temp drops to 30 and frezes items in refrig.
Set the refrig temp to 42 degrees . Also check to see if the damper (top left in refrig section ) is closing to stop the air flow into the fridge section . Sometimes they will stick due to ice build up inside the damper . Sometimes also , putting a knife inside and wiggling it around , will break it free , however , it may have to be replaced along with the #1 thermistor .
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
1,021 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
