Question about Dishwashers
LG Dishwasher My LG Dishwasher Model: LD 14AW2 Electronic stand alone keeps on coming up with an error E1? I am not sure what it is because we have no instruction manual. The dishwasher is about 2 1/2 years old. I am doing a standard (Normal) wash. It starts to put the water in side then comes up with the error.
  • Anonymous Mar 15, 2014
    I get a flashing E1 all the time
    need a manual for a LD 14AW2 LG Dishwasher
    Problem Solver:
  • 6 Answers
I have same dishwasher first check the water is cumming in if not remove the left side cover.1) the bottom tray is full of water you have a leak . replace the leaking part . 2) you will see a foam float toward the back of machine slide it up and down a few times to reset solenoid .3)on the left side you will see clear water inlet manifold give it a good hit after you first start the machine.
i have to do 3) about 1 every month
Posted on Mar 23, 2008
According to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Posted on Oct 20, 2007
I have a freestanding LG dishwasher and the E1 error message has come up. How do I fix it?
The E1 ERROR mean's your main wash motor is clogged or failed & you need to pull it apart completley to test or clear the blockage.Generally its just clogged so get a lg service guy to do it cause he will know your dishwasher inside out.THANKS, ECO KIZZA
Feb 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
Have E1 problem,machine stopped running,replaced washerpump/motor,runs for a few minutes E1 comes up and machine stops,any ideas
I had the same problem, new wash pump didn't solve the e1 error. New capacitor did the trick. Hope this helps
Jan 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
I hav a lg Dishwasher model # LD-14AW2 the problem
broken door cord. remove side panels and relace. this is a cheap and easy fit. make sure you replace both sides at the same time, you will most likely find it is only one side broken at this stage, but the cords do not last very long.<!-- from fixya rte -->
Jul 07, 2010 | Dishwashers
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
E1 code comes up on the display, but how do you solve this? ...
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Feb 18, 2010 | LG 24 in. LD-12BW5 Free-standing...
LG 24 LD-14AW2 HE ERROR - THE E IS FLASHING
try using only 2 teaspoons of soap powder (not tablets)
Feb 27, 2008 | LG 24 in. LD-12BW5 Free-standing...
E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Dec 23, 2007 | LG 24 in. LD-12BW5 Free-standing...
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
773 people viewed this question
Top Dishwashers Experts
