Question about Sony KV-32V26 32" TV
Sony TV KV-32v26
I have the TV hooked up but no default channels are coming in. I thought that most tv's would at least get the basic local channels. Do I need bunny ears for this? or is there someway to have the basics work without bunny ears. Thanks
  • 752 Answers
Do you mean basic CABLE channels or Aerial channels? If aerial, what kind of antenna are you using (you must have SOME sort of antenna... rabbit ears, set-top, etc...)?
Posted on Sep 20, 2007
SOURCE:
Sony KV-32V26 turned off while watching, now I can't turn it on
I have a set I'm working on right now, same model number and symptoms. It is a fairly common problem and the repair consists of replacing 3 transistors, one resistor and one VDR (voltage dependent resistor), along with re-soldering some connections on the main PC board. You'll need a technician to do the work, and it will likely be well over $100 to repair. I would consider replacing the set with a HDTV model if you can afford to. The picture tube may be the next to go.
Apr 02, 2010 | Sony KV-32V26 32" TV
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
Do i need just an antenna or one of those digital converter boxes to get just local channels in Denver on this TV?
If your TV was made after 2007 it should have the digital receiver built in. If so you can just hook any antenna you wish up and receive all your local channels.
Jan 15, 2010 | Sony KV-35S42 35" TV
No cable channels at all on old Sony Triniton
make it sure that the coaxial cable has its own signal! if your tv has a raster (sometimes blue) and it says that the tv is good, but if there's no channel at all then the problem is in digital converter or the connection of the coaxial cable comes from..you can also try auto programing but if the problem still occured then contak your cable subscription channel
Apr 03, 2009 | Sony KV-13M10 13" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV
Apparently, channels have to be autoprogrammed first before those buttons will work.
Our TV is 4 years old but we never used the channel buttons bc it was always hooked up to DirecTv thru video input. SO when we disconnected the TV to sell, we thought it was a problem.
Jan 06, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Bad reception on lower channels
Hello Moeggy,
Tuner of your TV set got defective and need to be replaced. Pls contact nearest Sony service shop for replacement of Tuner.
May 08, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron TV
I have seen this problem before.
The problem turned out to be caused by a poor solder joint on R530. This is in the HV
sensing circuit and is associated with IC501/ comparator. The resistor was replaced for
good measure and proper operation restored.
Jan 12, 2008 | Sony KV-32V26 32" TV
Can't get any tv reception
My friend, you need to hook up a signal source such as an antenna or cable . The channels wont come in and it will all depend on where you live and how close to a major city on what and how good you will get the stattions. then once an antennena is connected, do the auto programming again. Good Luck
Aug 18, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
