Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Windows could not start because of a computer disk hardware configuration problem. Could not read from the selected boot disk. Check boot path and disk hardware. I tried all 10 choices no matter what language; even the F8 in safe mode with choice one and still not working...Please advise
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    Are there any floppy discs, CD, or DVD in any disk drives? If so remove them and try to boot again. What was the result when you tried to boot to Safe Mode?
  • 741 Answers
Hard to give all the steps in this venue..go to about.com and type in "computer won't boot", I know the computer guy there, his name is Tim Fisher on that site and he has step by step instructions on what to do...
Posted on Apr 19, 2009
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
I have a dell optiplex320 windowsxp desktop,i cannot log on,a box comes up saying windows could not start because of a computer disk hardware configuration problem.could not read from the selected...
hello
well I can tell you it either it is Software (windows xp) or hardware your hard drive. you will need the windows xp disk.
IF YOUR DVD TRAY IS NOT OPENING THIER IS A PIN SIZE HOLE NEAR IT AND USE A PAPER CLIP TO STICK IT IN AND POP THE TRAY OUT.
hope the tray opens and then you can move on to a repair install.
here is how to do a repair install 10 steps
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
hope that helps
Aug 17, 2013 | Dell Computers & Internet
Asus eee 900 disk hardware configuration
Have you checked BIOS settings to make sure the right harddisk is selected as Boot Drive ?
You could try installing it on another machine to make sure it's still readable.
Did you change any settings or get any error messages the last time you used it ?
Jun 18, 2012 | ASUS Eee PC 900 Notebook
Windows could not start because of a computer disk hardware configuration problem. Could not read from selected boot disk. Check boot path and disk hardware.
It appears that your system can't find any bootable device such as the hard drive. Go to system BIOS and check if the hard drive is detected. By pressing F2/Delete key while starting up it will boot up to your BIOS screen. You could also try to load the system BIOS default.
Dec 30, 2010 | ASUS Computers & Internet
Acer says this when i sign-on: Windows could not start because of a disk hardware configuration problem. Could not read from the selected boot disk. Check boot path and disk hardware. Please check the...
It's not able to see your hard drive. Something may have changed in CMOS about the boot order. You should enter the bios and see if it sees your hard drive. Then go into advanced boot options. First boot object is usually set to CD Rom for setting up operating systems and the second boot device should be your hard drive. Third boot option can be left at none or a floppy drive if you have one. If the bios is seeing your hard drive and it is set as a boot option then the drive may be damaged or system files have been lost. If there are valuable files on the hard drive and it is failing then you might consider taking this to a professional and trying to rescue your files asap before the drive deteriorates any more than it is. You can also try some repair options from booting off the Window's CD but beware that formating your drive is one of the options and this will erase any files you have on the drive.
Nov 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
Could be a serious problem.
next time you get it running, right click on my computer>explore, click on 'C' drive, right click>properties>tools tab, then click error checking, if the option to choose repair found faults, choose it, then the system will run a drive check.
It may take a few hours as it sounds as though you have a bad sector on your drive, back up all docs immediately after the system as run a check and hopefully is up and running again
Aug 16, 2008 | Dell Inspiron 6000 Notebook
New hard drive to install windows sayind
If you have not checked these(I am sure you have probably gone through this or don't need to but just in case)
First thing is first you have installed a new hard disk, is this the only hard disk installed. If Yes, does the bios recognize it? If Yes, is it bootable. Meaning is there a working copy of windows installed? If not reinstall from windows installation disk. If Yes, you may still have to reinstall windows you can use the windows installation disk as well.
This sounds like an issue that I had taking a hard drive from one computer and placing it in a brand new one. This message sounds like windows is damaged. I had to reinstall windows and leave the file system intact. There is an option to do this. If you feel comfortable you can always use a boot disk and check the boot .ini to make sure that it has the correct path for windows written in that may be the issue there. This file is hidden in the root directory of the drive.
Nov 30, 2007 | Computers & Internet
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
