My computer cant find my printer its a lexmark 2600
Every time i try to print a photo my computer tells me it cant connect to printer and its connected properly plus its installed properly someone help plz???
  • 1 more comment
  • german_sj Apr 21, 2009
    Well No it cant i tried the exact words is THE PRINTER CANT COMMUNICATE WITH THE COMPUTER.....that keeps poppin up every time i try to print something
  • Anonymous May 22, 2009
    My computor says there is no connectivity between itself and my printer.I have tried all that is suggested.
  • Blue Sky IT Strategies
    Blue Sky IT Strategies May 11, 2010
    Can you print text to the printer?
    Scholar:
  • 132 Answers
Have you tried the following steps?
1. Power off your computer.
2. Power off the printer and remove the power cord.
3. Check the cable connection between the printer and the computer to make sure it isn't loose.
4. Put the power cord back in the printer and power it up. Do all lights show up as normal? Green? Or are some flashing?
5. Power on your computer.
6. Under the printers folder, right click the installed printer and go to properties. Print a test page.
How is the printer connected? USB or parallel port?
Posted on Apr 21, 2009
Installed new printhead on Lexmark s305 and now my adobe photoshop elements 10 program can not scan but prints fine.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/guXLhl. Select your operating system, download and execute the file.
Mar 08, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Lexmark 2600
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system, download and execute the file.
Jan 11, 2012 | Lexmark Office Equipment & Supplies
My lexmark X7170 Printer Skip line when printing how do fix it
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Jan 03, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
  2. Go to Programs.
My lexmark 2600 is ON and rdy but my comp doesnt see it after making a USB connection so i cant use it to scan and print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
When I press print I get the following message: "The Lexmark 2600 series is currently busy. Your print request will begin as soon as current processing is complete". Nothing prints. The...
There could be some print jobs stuck in the print queue. Try to clear the print queue first before sending a new print job. Follow these steps: - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- Browse to your windows\system32\spool\PRINTERS\ folder - You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files. - Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service) - Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again.
Apr 25, 2011 | Lexmark X2650 All-In-One InkJet Printer
Lexmark 2600 printing problem
You might try deleting the printer from the 'Printers and faxes' folder in the Control Panel, reboot with the printer connected and turned on. Win should 'find' it again and reinstall the driver.
Dec 22, 2008 | Lexmark X2600 InkJet Printer
Lexmark 2600 installed-scanning works fine connected USB cable but can not print from computer
plz try by reinstalling the drivers and check are you printing from the correct printer
Aug 18, 2008 | Lexmark Office Equipment & Supplies
Printer Problems
MY LEXMARK Z615 DOES NOT WORK WITH BLACK CARDIAGE
Oct 13, 2007 | Lexmark Z615 InkJet Printer
150 people viewed this question
jasbo
jasbo
