Question about Craftsman Garden
Possible carburetor problem? Mower runs for
Possible carburetor problem? Mower runs for awhile, gets hot and stops running, also leaks gas. It's a craftsman lt 1000 riding lawn mower.
I have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Posted on May 08, 2010
Carburetor leaking gas
If the mower is not running and gas is leaking from the carburetor you can be pretty sure that the float/needle valve are not closing off the fuel and the bowl is overflowing.
If the mower has not been running and not properly prepared for storage it will most likely be residue left behind after the gas has evaporated.
Most likely is that the float is stuck to the bottom of the bowl.
Apr 06, 2016 | Briggs & Stratton Garden
Masport 635 starts, revs up once, and dies. Will start again a few pulls later. Carb diaphragm has been replaced with no change. Could it be ignition? Thanks.
follow this steps and fix it. God bless you
Carburetor
If the lawn mower engine stops after a few seconds, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the lawn mower for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
Carburetor Kit
If the engine stops after a few seconds it may not be getting enough fuel. The engine needs air, fuel and spark to maintain operation. The carburetor has two inputs, fuel from the gas tank and air through the air filter. The carburetor is designed to mix the air and fuel in a consistent ratio so that the engine can run continuously. If the carburetor is not getting enough air or fuel, or if the fuel is blocked inside the carburetor the engine stops after a few seconds. Rebuild the carburetor with this carburetor kit.
Gas Cap
If the lawn mower engine stops after a few seconds and then stops running, the gas cap might be defective. All gas caps have a small vent to allow air back into the tank when the engine is running - otherwise as gas is drawn from the tank it would create a vacuum. The vent can be difficult to see and there are many different types of vent. If loosening the gas cap a little allows the engine to stay running, replace the gas cap. It's sometimes possible to clean the vent, but on most newer engines the vent cannot be cleaned, it should be replaced.
Gas Cap with Gauge
If the lawn mower engine stops after a few seconds and then stops running, the gas cap with gauge might be defective. All gas caps have a small vent to allow air back into the tank when the engine is running - otherwise as gas is drawn from the tank it would create a vacuum. The vent can be difficult to see and there are many different types of vent. If loosening the gas cap a little allows the engine to stay running, replace the gas cap. It's sometimes possible to clean the vent, but on most newer engines the vent cannot be cleaned, it has to be replaced.
Old or Bad Gasoline
If the lawn mower stops after a few seconds, the carburetor might be clogged or have old or bad fuel in the float bowl. If old fuel was left in the lawn mower for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This old or bad fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old or bad fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
Spark Plug
If the lawn mower engine stops after a few seconds the spark plug might be defective. All small engines have an ignition coil. The coil is the device that provides spark for the spark plug(s). If the coil is bad there won't be spark to the plug(s). The coil is essentially a small, induction generator. It is mounted next to the flywheel. The flywheel has one or more strong, embedded magnets. As the flywheel spins, the magnet(s) zip past the induction coil, this action of a magnet passing past a coil induces a voltage. Depending on the design of the coil and the strength of the magnets, a stronger or weaker spark can be created and delivered to the spark plug(s). Each time the flywheel spins around a spark is generated. The best way to test a spark plug is to use a spark plug tester. The spark plug should have a strong, visible spark between the electrodes when the engine is cranking. If it doesn't, replace it.
Nov 13, 2013 | Garden
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
It will not stay running I have to choke it to start it then it dies after I take the choke off it's die. It just act like it out of gas I changed the fuel filler
not getting gas, since gas is going to carburetor then the carburetors float/needle is not working, will need to clean/rebuild/replace carburetor. I am assuming that the mower sat awhile with gas left in it and the gas has gummed up the carburetor, sometimes it will clog the lines,filter and pump, you can use carburetor cleaner to clean it up and you may want to try blow air through the ports, Good Luck Tim
May 30, 2011 | Garden
I have a 7 year Craftsman 17.5 HP 42 in. lawn tractor. It starts to leak gas recently and stops frequently after running over 30-40 minutes. I can not identified where is the gas leak from but I saw gas on...
I have a Craftsman mower. Last year I had a similar problem with the mower stopping after running awhile. I noticed that the plastic gas tank was collapsing. The next time it began to stall, I immediately loosened the gas cap and it didn't stall. The vent holes in the cap had plugged up. Check this out.
I can't help you locate the fuel leak, although it sounds like the carburetor float is not stopping gas from flowing into the carburetor.
Dec 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MOWER ONLY RUN WHEN U PUT GAS IN CAB WANT START
Ok, so your not getting gas to carberator, or thru the carberator. Disconnect gas line from carberator, if gas is present thru fuel line, you have a carberator problem. Your rather meger with your mower information so this is all i can tell you. Wish i could be of more help.
May 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My mower starts and runs until the engine get hot.
the only way to test i think is with a known good coil or resistance check. also possible you need to check valve clearances
Apr 25, 2017 | Toro Lawn Mower With Toro Power Tools
Mower stalls out after about an hour of run time
A few possibilities
1. If engine runs hotter than normal it can eventually heat up the carburetor to the point that there is a vapor lock. Blockage caused by gas bubble: a bubble of vaporized gasoline that blocks the normal flow of fuel. Problem goes away when things cool down. If that is the problem, you need to solve overheating problem. Since you have changed the oil, might be something blocking airflow to the flywheel which has the cooling blades on it. Or cooling blades are filled with debris. Make sure vent hole in gas cap is not blocked
2. Could be bad coil, or condenser causing the windings to act up when they are hot and have expanded they short out (kill engine) on their own casing. After they coil and shrink, they un-short themselves.
May 14, 2009 | Garden
Garden Logo
936 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
