Question about Garden
Unable to start check oil is full and gas tank is full
  • 10 Answers
Check spark & spark plug.if you have water on trigger must be engaged as you are turning pump also creating pressure this stops engine turning fast enough even if you pull rope hard as you like engine does not operate run cycle properly.
Posted on Apr 20, 2009
Why is there gas in the oil of my 1983 goldwing
Hi, Anonymous you're getting ready to go riding you pull out the dipstick to check your oil level and are greeted with the unmistakable smell of gasoline. What happens next depends on the following:
1. You have experienced this before and do not start the engine but do change your oil and filter leaving it 1 quart low until the engine reaches operating temperature then top off as necessary.
2. The amount of time your bike has been sitting since the last time the engine was running.
3. The amount of gas and contaminants in the tank.
4. The oil pump location, exterior or interior.
5. The condition of your petcock gasket/seal/diaphragm.
If your gas tank was low and you start the engine probably nothing you would notice but if your gas tank was full and you start your engine the oil/gas mixture can blow into your air filter, come streaming out of your crankcase breather hose, and launch your oil tank cap followed by a blast of oil. The mess can be minor or you need to call a Hazmat team for assistance. This will also happen if you overfill your oil tank.
Next is the how and why gas can get into your oil tank/system:
a. The vacuum petcock rubber/diaphragm fails, which allows gas to flow from the fuel tank through the petcock, through the vacuum line into the intake manifold, then into the combustion chamber, where it seeps past the piston rings and into the bottom end.
3. Nonvacuum petcocks that are not turned to the off position will patiently wait until contaminants from the gas tank build up in between the carburetor needle and seat breaking the seal thus inviting gas to enter the combustion chamber eventually finding it's way into the bottom end and the oil tank.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
oil has gas smell GL1100 Information Questions goldwingdocs com
GL1200 gas in oil
Honda GoldWing GL1100 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Gold Wing GL1100 Owner Manual
Jun 16, 2014 | 1983 Honda GL 1100 Innerstate Gold Wing
Ran perfect last yr , gas was stale drained carb bowl and replaced gas it started up right away then cuople mins later it started blowing oil out of the oil over flow tube
Sounds like the Needle valve in the carburetor is stuck 'down' letting gas continually run from gas tank into carb. When the valve can't go up (Close) gas will run past the carburetor and into the crank case I bet your oil is full of gas. Check oil level see if it is overfull
Jan 22, 2014 | Tecumseh Snowblower Snow Blower Starter...
2001 Triumph Legend TT engine oil flooding with petrol
Hi, Malcolm you're getting ready to go riding you pull out the dipstick to check your oil level and are greeted with the unmistakable smell of gasoline. What happens next depends on the following:
4. Bottom line if you're not going to ride your bike for a while turn off the petcock.
Legend leaking lots of fuel from airbox Problem Solving Tech Forums...
gas in oil
Triumph Thunderbird Service Manual
Hermys Tire Cycle Inc 2001 Triumph Legend TT Genuine Motorcycle Parts in...
Triumph Thunderbird Owner Manual
Jul 05, 2017 | 2001 Triumph Legend TT
Gas in oil tank 2006 vtx 1300@
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Gas smell in oil
http://www.fireblades.org/forums/general-discussion/74389-gas-oil-problem-again.html
Honda VTX1300S Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2007 VTX1300S Owner Manual
Jun 27, 2012 | 2006 Honda VTX 1300
Honda 2004 CBR 125 R with 50,000 km smell of petrol in the oil
Oil smells like Gas
Fuel smell in oil
Honda CBR125R Owner Manual service
Honda CBR125RW Owner Manual
Jun 16, 2012 | 2004 Honda CBR 125 R
Bought unit new last summer. Used it once last summer and once this year. It started fine both times. Today, it will not crank. I have replaced the spark plug, checked the air filter (it is clean), gas...
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Oct 13, 2010 | Craftsman Garden
2001 KTM Exc-Racing E 400 oil smells like gas
Hi, Frank_sydow you're getting ready to go riding you pull out the dipstick to check your oil level and are greeted with the unmistakable smell of gasoline. What happens next depends on the following:
is it possible to have gas in the oil on 4 stroke ATVConnection com ATV...
oil smells like gas
http://www.keustermans.nl/KTM_RFS_Workshop_Manual.pdf
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 400 EXC RACING Owner Manual
May 19, 2017 | 2001 KTM Exc-Racing E 400
Low flame
close the air vents to the burners
Jul 05, 2010 | Weber Genesis Silver B Grill
I have a 1988 Ford F250 with the 460 engine and duel tanks it is factory fuel injected.....the front tank ran out of gas so I switched it to the rear tank( the same as many times before) the truck died and...
The fuel pump relay and the oil pressure switch as well. The oil pressure switch runs power to the fuel pump when you first start it
When the oil pressure reaches operating range the relay takes over
They are both inexpensive so replace both of these parts to be safe and kill two birds with one stone. If one goes out the other will soon enough
Mar 27, 2010 | 1988 Ford F 250
Onda generator engine starts and then 3 or 4 seconds later stall
Oil pressure switch. Check it and make sure oil level is correct. The oil switch will cause this
Aug 31, 2009 | Electrical Supplies
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
