Question about Refrigerators
My Kenmore 363.58261896 is not cooling. Fridge temp is about 50 F. Freezer is about 30 F. I've vacuumed the coils and even around the fan. Fan is running fine. Before this happened, I was having trouble with ice forming on the floor of the freezer. (Not sure if that's related.)
  • brettmoran Apr 26, 2009
    363.58261894 refrigerator not cooling; freezer works fine.
catriver
  • 878 Answers
SOURCE: Freezer works fine refridgerator does not
anan, I think your display is giving you a code on these LG. See if you can find the tech sheet behind the toe panel. On your display panel from memory, 3 led's lit from the left means a failed defrost thermistor. This could be the reason you are frosting up and restricting the air flow. There is a main board in back that you can ohm out the thermistors. Connector 4, the two bright orange wires #5 and 6, should ohm at 19K ohms at 50 degrees. Now Im doing this from memory, if you can find your tech sheet, it will give you precise information. Catriver.
Posted on Jun 14, 2007
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
22yooper
  • 828 Answers
SOURCE: KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
Posted on Jun 03, 2008
SOURCE: Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
Posted on Jul 13, 2008
Benimur
  • 6966 Answers
SOURCE: Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 02, 2008
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
Freezer side and fridge side not working, temps are freezer 30 fridge 50
Most likely the condenser coil is dirty. It is under the fridge, clean it with a vacuum, or air pressure, blow it out outside it will ne dusty . There are two to three fans. One by the compressor, called a condenser fan. If it is a side by side, usually there is a fan in the freezer section, and one in the refrigerator section. All need to work. If all this is and the compressor is running then chances are the compressor has bad valves. Make sure there is no ice on the coils in the refrigerator and freezer coils. If there is ice you have a defrost problem, which can be fixed. If the compressor has bad valves, get a new refrigerator.
May 08, 2014 | Maytag MSD2454G Side by Side Refrigerator
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Refridgerator not cooling
That fan at the top has to remain on during cooling or you get the temps. you describe. To check this you need a voltage meter. Got to get to the fan and have to check if there is voltage 120v when it shuts off. If there is still voltage present when it shuts off then change the fan, if no volts when it shuts off then change the timer. need complete model cause this one may have an adapative timer.. i fixed one with the same problem last year.
Mar 28, 2010 | Refrigerators
Freezer working but Fridge not cooling... Tried adjusting temp to max cool and nothing. Unblocked vents, still nothing... Pulled off back panel cover to vacuum and brush... still nothing... help??? In case...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 26, 2009 | Amana ARB1917CSR Bottom Freezer...
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Kenmore Refrigerators
SIde by Side Kenmore -- Freezer is fine Fridge Is Warm
the freezer needs defrosting or the evaporator fan has failed and is not blowing air into the refrigerator side.
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
High temp red light stays on...
You'll need to tear into it to answer these questions. I suspect the defrost cycle isn't working or the fan is broken. The best way to see what's going on is to take everything out the freezer drawer and remove it. Then take the back panel off the interior rear wall of the freezer section to expose the coils. The coils should have a very even white frost pattern on them (not frozen solid anywhere). If they are frozen up then the air can't flow around them to cool the fridge properly. If the coils seem "normal" with frost only then is the fan just above them working? That fan circulates cold air to both fridge and freezer sections. Let me know what you find out in order to lead you to a repair part.
Jan 12, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
