Question about Flotec Simer/Flotec/Omni 2105 Swimming Pool Cover Pump
Pool pump not working
Hi, I bought a Flotec Submersible Pool/Spa Cover Drainer (Model # FPOS1790PCA) about 2 months ago, worked great, suddenly it stopped..we cleaned out the leaves and debri from the filter and checked the hose for a clog but it was clear. We also made sure the outlet was live. When we plug it in the red light doesn't come on, I tried resetting it. Is there a fuse or something? Thanks for your help. :) I don't know what category to pick...so if you can't help me can you suggest someone else?
  • 547 Answers
There would not be a fuse if this has a reset button I would suggest you return to company you got it from and have them replace the defected one thank you
please rate me
Posted on Apr 20, 2009
STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
Aug 03, 2012 | Flotec Plumbing
I purchased and installed this model pump (FPOS1790PCA). The first couple of times there was water on the pool cover, the pump seemed to work fine. I have several inches of rain water on the cover...
You may want to check with Flotec first since many of the manufacturers handle warranty claims directly instead of the store being involved. If the unit falls within the stores return period then just take it back and excahange/return it...if not, Flotec is at: http://www.flotecpump.com/ResidentialContactUs_ContactUs.aspx
Select warranty from the drop down menu and go from there.
John
Apr 19, 2011 | Flotec 2115 Swimming Pool Cover Pump...
I bought my rule pump 1800 hp 1 yr 3 months ago now wont work what should i do
check that the impeller on the bottom is't frose or debre pluging the pump push a stick in the out nozzle to turn the impeller try again see if it works
Feb 27, 2011 | Rule 1800 H53SP-24 Swimming Pool Cover...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
I have a Flotech FPOS1790PCA Pool pump that will run for 15 seconds and then shut off...how do I get it to stay running?
I have the same model and found that it frequently shuts off when it gets too much pine needles clogging the strainer.
I have unscrew the bottom "skirt" almost once a month and clean it out.
Nov 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pump keeps turning off
this pump needs about 21/4" of water to operate properly, this pump will not remove all the water from the cover and will cycle on and off as it looses prime. If the motor turns completely off, it may be a an issue with low line voltage. you can try using a lager gauge extension cord to try and fix it, otherwise have an electrician test the line voltage.
Here is a pdf of the manual:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000049529.pdf
Sep 16, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pump is leaking oil
very iffy to get to seal properly and for the $40 bucks cheaper to get new one
Apr 29, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Jan 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Flotec Simer/Flotec/Omni 2105 Swimming Pool Cover Pump Logo
428 people viewed this question
Top Flotec Pool & Spa Experts
Jay Finke
Jay Finke
Bill Boyd
David Spradling
David Spradling
Are you a Flotec Pool and Spa Expert? Answer questions, earn points and help others
