Question about Amana ATB1832AR Top Freezer Refrigerator
Amana ATB1832ARQ Top Freezer Refrigerator - Freezer door not seal
This refrigerator is only a couple of years old and just now the freezer door does not seal on the side by the handle. (Since our children are grown and on their own, we can't blame them for swinging on the door.) It seemes like it happened all at once. Can the door be adjusted? or does the gasket/seal need to be replaced. If there is a magnet in the seal, it sure is weak. I can push the seal against the body of the fridge, but it doesn't stick there.
What is the manufacturers warranty? Thanks
  • morriskeelin Apr 25, 2009
    I had ot put a real thin shim behind the hinge, (made from the cardboard of a cereal box) and it worked. Thanks
  • George seymour
    George seymour Jun 16, 2014
    I just hadthe same problem. Somehow it had become dislocated from the track. It also had a space of a quarter inch on the top corner that closed when I got it back on track.
    Problem Solver:
  • 19 Answers
OPEN THE DOOR WIDE . YOU SHOULD SEE THE HINGES THAT SUPPORT THE DOOR. LOOSEN THE SCREWS THAT SUPPORT THE DOOR----JUST LOOSEN , THEN LIFT UP ON THE DOOR AND TIGHTEN THE SCREWS. NOW YOU CAN LET GO OF THE DOOR. I HOPE THAT WORKS FOR YOU . GOOD LUCK.
Posted on Apr 22, 2009
I have a three year old Amana ABB2527DEB. The Freezer seemed to be overworking and the fridge was 68 degrees. Took everything out of unit and unplugged it for more than 24 hours. Cleaned it inside,...
This could be a double problem.
Yes the auto defrost cycle seems to have failed allowing an ice build up.
Secondly the door seal is leaking allowing warm moist air to sneak in. You probably need a door gasket too.
Apr 04, 2011 | Amana ABB2527DEW / ABB2527DEB / ABB2527DEQ...
Refrigerator is warm, but freezer is cold and still making ice. This is a 3 year old Amanna Bottom Freezer model. There is frost in the top of the freezer drawer when I putt it out.
you will need to defrost it. the freezer is what keeps your fridge cool. the vent where the cool air goes up to your fridge is sealed or frozen.
unplug the fridge and open the doors and let it defrost.
plug it back in after a few hours and it should be working again.
Mar 20, 2011 | Amana ABB2223DEQ Bottom Freezer...
Bottom freezer is fine but top refrig. is warm. Have vacumned bottom front coils, unit less than 2 years old. Any suggestions, other than calling repair? thanks.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Amana AFF2534FE Bottom Freezer French...
Amana refrigerator door gaskets not inflated and do not seal prop
you might need new door seal :
Refrigerator gasket Number: 67003548 70$ and see if it EZ to replace...good luck
Jan 01, 2010 | Amana ABB1927DE Bottom Freezer...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My frigidaire refrigerator is sweating on the inside. what should i do? its a one door model with ice maker and freezer on top. i don't remember the model. 5 years old.
High humidly could cause condensation or the magnetic seal could be bad.
A couple of things to try;
The easiest thing to do first is to clean around the rubber seal very good with mild soap and water and the metal which the magnetic rubber seal contacts to seal the door. If you find a crack or a deformation of the seal it will let condensation it the refrigerator.
Does the freezer auto defrost or is a lot of ice bult up around the freezer walls? If so manually defrosted the freezer.
Dripping from the Ice maker water supply?
Jul 15, 2009 | Frigidaire Refrigerators
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana bottom freezer refrigerator
could be the cause. check by putting a slip of paper between seal and cabinet and with door shut, check paper is gripped all round the door. if it is not, try warming the seal with a hairdryer in the faulty place and pulling the seal out gently. many of these seals are foamed in and impossible or v dificult to replace. check also that the hinges are not worn
Jun 14, 2007 | Amana ARB2257CSR Bottom Freezer...
Amana ATB1832AR Top Freezer Refrigerator Logo
364 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
