Question about HP Color LaserJet 2600n Printer
Says paper jam, no paper inside
I have a hp lasejet 2600n printer, it says there is a ppaer jam but I don't see anything in there, is there some where I am not looking. Amy
If you are getting a paper jam error, but no paper inside- Check your Pick Up rollers in the paper tray and then check for any stuck flags in the printer.
Posted on Sep 20, 2007
Out put jam in the printer 2600n hp
This could be a fuser issue or a paper exit sensor issue. Please take out the fuser and check the pressure roller. Be careful, the fuser is extremely hot.
May 11, 2015 | HP LaserJet Office Equipment & Supplies
We have a HP Laserjet 2600N. There is a jam in the fuser delivery section. Someone tried to clear the jam but left torn paper inside. How can I remove the jammed/torn paper? Is there a lever that will...
I'm sorry to inform you I referenced the removal of the fuser as it's simple for most machines. However on the 2600 it's buried inside. If you can pull it out the machine will have to opened up to remove the paper. The process includes 18 steps to get it out.
If you want the instuctions on how to remove I can upload them to scribd and provide you with a link. Other than that it would require a service call to a technician or your IT department.
Oct 20, 2010 | HP Color LaserJet 2600n Printer
My printer has the problem of pepar jam
if the printer says its jamming and there is no paper jam.. change the pickup rollers.
if there is a jammed piece of paper then more info would help.
-printer name / model / make ?
-exactly where it is jamming (paper tray, inside the printer when you open it up.?
Jul 21, 2010 | HP Color LaserJet 2600n Printer
How can i repair my hp laser jet 2600n printer when paper jam
Hi. I would suggest cleaning your printer on the inside and removing any blockage from rollers or look for any peace of paper that's clogging any device inside your printer. Also try pressing all the sensors inside to check if they are not stuck or something. Hope this helps
Jun 04, 2010 | HP Color LaserJet 2600n Printer
Paper jams
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 23, 2009 | HP Color LaserJet 2600n Printer
HP 2600n Ironing transfer paper jammed around top roller
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Jun 05, 2009 | HP Color LaserJet 2600n Printer
Paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Jul 27, 2008 | HP Color LaserJet 2600n Printer
Paper jam
The paper jams are in the fuser area. Which is very hot. The following is a link to change the fuser. It may be that you can get to the jam by removing the top cover.
Jul 01, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
392 people viewed this question
Clive
Clive
