Question about GE WDSR2080D Top Load Washer
Machine wont agitate
GE wash machin fills up then will not agitate it thinks it is washing because soon it will empty just wont agitate during wash
  • rickreich May 11, 2009
    Wont agitate....
    Check the thermal fuse. It is in the wiring harness that goes from the dial control to the motor. If you remove the dial cover assembly and the face of the machine you will find a wireing diagram that will show you how to locate the thermal fuse. In the primary wireing harness running down the front right hand side of the machine wrapped in electrical tape and hiden in a shrink tupe. Radio shack has the fuse for under 3 bucks and some shrink tube for about 4 bucks and you have it fixed. screw the tech it is a waste of money.
  • 3,741 Answers
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Aug 20, 2009
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Agitator doesn't run
The problem could be transmission failure
May 23, 2013 | GE WWSE5240D Top Load Washer
Sounds like a jet plane taking off when it spins, I think I got in 2003 Also the top of the agitator wont stay on
Has it always sounded like a jet plane? If it has. Then who installed your new washing machine didn't disengaged the two counter weight inside the washing machine. There two concert block or plastic block inside the washing machine. Each block is attached to one end of counter blanching bar which has some spring attached to them. During manufacturing these weights are tied down for shipment. During installation the ties are removed then the washing machine can be leveled.
Counter weights are used to off set the uneven load in the tub. That way the washing will not start walking in the house. Side load washing machine use a plastic donut the fits around the drum and it fill with fluid for counter weight.
Now the cap of the agitator, it broken. The locking tabs are broke off. needs to replace. I hope you said the top of the agitator and not the agitator is coming out. If it is, you got major problems. stewbison
Aug 20, 2011 | Amana Washing Machines
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
My washing machine is stuck on agitate. It filled and agitated then stopped. I can set it to spin only and it will spin and empty the tub, but for a regular wash cycle it starts on agitate and stops...
You may have broken teeth on the gears in the timer assembly. Do you have a habit of "whipping" the timer around? In other words, turning the timer fast.
Dec 14, 2009 | GE Washing Machines
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
GE WDSR2080D Top Load Washer Logo
268 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
