Question about Lexmark X73 All-In-One InkJet Printer
Scanner will not scan
The Lexmark allin one printer X73 that scans E-mail faxes
    Sergeant:
    Champion:
  • 293 Answers
Set this options un der Control panel Scanner and camera. If fails try this, Uninstall everything HP Installed. Unplug the scanner. Then reboot. THen install the drivers and applications. Then reboot. then insert the HP scanner into the USB.
Posted on Sep 20, 2007
SOURCE:
Lexmark scanner will not scan to computer
Have you tried scanning using our Lexmark Printer Home software? To access the Lexmark Printer Home software, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
If it doesn't work, please contact our technical support team so they can do some diagnostics.
Jan 04, 2013 | Lexmark OfficeEdge Pro4000c -...
I have a lexmark 464de mfp. How do i setup scan to e-mail on windows 7 on this network printer?
Multi-function printers cannot scan and then e-mail the scanned image. They can scan and then fax a document.
You need to scan the document, then save the scanned image, open your e-mail program and create the e-mail then attach the image file (file attachment) to the e-mail before you send the e-mail.
Jul 08, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Can lexmark x1160 printer scan to computer or e-mail
Most multi-function scanner printer cannot scan to e-mail. They can scan and fax if it has a phone line connection.
You can scan and save the scanned doument as an image file and then send an e-mail with the image file as a file attachment.
Jul 07, 2011 | Office Equipment & Supplies
Windows 7 64bit, home network. Lexmark interpret s405 all in one.Trying to scan with windows fax and scan. can printer with no problem. windows fax and scan cannot find scanner. I look in device manager...
Try to re-insert the installation disc that came with your printer. Run the disc and make sure to install the Lexmark scan driver. If you have a firewall enabled, make sure to allow all access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
May 11, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have a lexmark x73 i'been instaling so manytimes on order to make the scaner to work but nothing I would apreciatte if you can give me some tips or help thanks
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X73) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Lexmark X73 All-In-One InkJet Printer
I have here a Lexmark X73 copying machine,fax,scan,e-mail and I am tring to get it connected to my tower which is HP pavillion could you help me with this hook up
jfergie, did your computer give you an error message or you are in the initial method on getting this one working on your computer?
Sep 12, 2008 | Lexmark Office Equipment & Supplies
Faxing
WEll the x7350 is a fax and scanner and copier plus printer. Which x73 do you have?
Jul 27, 2008 | Lexmark X73 All-In-One InkJet Printer
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
Scanner, files,and the faxing screen
You downloaded wrong drivers:::
please use this link to download and install the software:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:0:0:0
Mar 06, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
94 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
