Question about HP Officejet 6310 All-In-One InkJet Printer
Printer Driver Not supported by Windows Vista Home Premium Edition
  • 83 more comments
  • JASON VOGEL Nov 02, 2007
    help
  • aspa Nov 04, 2007
    The printer will not work...I have tried everything...apparently the drivers are there but there is a file missing...Im prompted to go to hp drivers but it says vista has the drivers and I dont have todo anything!!!but no luck!!
  • Anonymous Nov 16, 2007
    After vista installation duplex printing is upside down and lower tray doesn't work.
  • Anonymous Nov 20, 2007
    can not use it with vista
    not compatible for vista
    the driver isnt compatible to vista
  • Anonymous Nov 21, 2007
    xerox docuprint n17 not compatible with windows vista. are there any compatible drivers to make n17 print from vista platform?
  • nitti Nov 21, 2007
    i have purchased new vista home system and when I tried to take a print out of a document prepared in word it doesn't work. My dealer suggested to me since the xerox which I am having compatible only with intel xp, I have to instal the driver with vista home
  • jc_ted Nov 26, 2007
    I have just got a new computer running on Windows Vista, but cant seem to get a print driver anywere to install my HP designjet 100, is there not one available? or is there an alternative solution? can someone please help!!!
  • oldgeeser Nov 27, 2007
    Can't print CD's with Windows Vista worked great with XP.
  • Anonymous Nov 30, 2007
    Windows Vista Driver
  • royalsilver Dec 05, 2007
    the printer software will load but the fax software does not load it says this system does not match the supported operating system so I can print but cant fax
  • Anonymous Dec 08, 2007
    HP DeskJet F380 All-In-One Printer i could not find driver for windows vista
  • Anonymous Dec 10, 2007
    I purchased a new desktop with vista, but the computer will not boot properly if my mp390 is attached. If I wait to plug it in after vista is up, the printer works fine.
    printer not supported by vista
  • boilingice Dec 12, 2007
    same this wit me. MP160 not working with vista. it says unknown device. even after installing the driver from canon website which was supposedly for vista. Vista really sucks. Any help please?
  • Micl Dec 15, 2007
    I have download the driver of Canon Pixma MP160 for Vista. And i tried to install but there is error message at between the installation of driver
  • marviwn Dec 21, 2007
    I have gone through the "Gestetner" web site and was unable to find any driver that works with Gestetner Dsm618 printer. Need a driver that works on Windows Vista???
  • 1medmadman Dec 29, 2007
    We tried to install the Xerox DocuPrint 4517 driver under widonws as suggested below by going to ControlPanels>Printers>Add Printer>
    we chose to install it on a local port,the virtual USB 0001 printer port,
    sent a test page and nothing happened.
    How do we associate the physical cannon printer device with the (possibly)
    virtual printer we installed?
    vista still give us the "found new hardware" dialog every time we plug in the printer.
  • Rickyh33 Dec 31, 2007
    can't get a driver for vista for the Lexmark p4300 all in one printer
  • Anonymous Jan 01, 2008
    Will not print at all when trying to copy something. It did and then next time would not. Put new cartridge in but still does not print when you try to copy. When you try to print the help button it will not print it either.
  • Anonymous Jan 02, 2008
    When installing the 6200 series software,the scanner and printer software failed
    having problems installing it on a system with Vista home premium
  • gunther_d Jan 04, 2008
    Can find no driver for samsung spp-2020 for Vista Home Premium
  • Anonymous Jan 07, 2008
    i have had x1195 previously loaded to my computer on windows vista home primium, but it has some how been removed, I have actually used this printer with my operating system!!
  • Anonymous Jan 09, 2008
    have a lexmark printer 6200 wont work on windows vista but did on windows xp
  • Anonymous Jan 10, 2008
    The postscript-driver for XP also works on Vista
  • stin Jan 12, 2008
    I cannot get my hp 1410 printer driver to install on my new windows vista operating system
  • Purrgo Jan 26, 2008
    using laserjet 6l with Vista home premium via a USB hub as there is no parallal port on my new Dell 531S. The connection is flakey and often drops out. Print job spools, but results in an unspecified error.
  • Hubby ME Feb 04, 2008
    Vista tells me I have no driver for printer immediately after printing out!?
    Printer properties shows an unspecified error with documents spooled waiting upon retry of printing exactly the same file. Vista drivers supplied by Samsung cannot be found on CD by Vista. Arrrrrggggghhhh!!!
  • Anonymous Feb 17, 2008
    Lexmark Z45 is not working with Vista Home Premium system. Does not properly install the original driver from disc. Patsy
  • Pashnar Feb 19, 2008
    Installed drivers and software OK on Vista Premium Home Edition. Photos go through the print routine OK and appear in the print spooler window, but nothing happens.....
    all installs OK and works on XP machine.
  • Anonymous Feb 25, 2008
    Need a driver for Windows Vista!!!
  • Anonymous Feb 26, 2008
    Printer not supported by MS Vista. Tried to download a driver but found only a 15 day trial for some sort of multi-drivers
  • Anonymous Feb 29, 2008
    tengo una samsung SPP-2020 que no me funciona con windows vista y no encuentro unos drivers validos, me pueden decir donde los puedo encontrar
    I cannot get the drivers to load on my vista system - tells me not enough memory
  • Anonymous Mar 08, 2008
    I have tried the support from Printer's support website
  • boysie1 Mar 13, 2008
    REMOVE RIGHT CARTRIDGE ERROR MESSAGE EVEN THOU NEW ONE IS INSTALLED
  • VE2SJ Mar 17, 2008
    cannot install multipass mp-360 driver in my portable dell computer with windows vista OS
  • fabu2006 Mar 31, 2008
    I cannot scan
  • lalilulelo Apr 03, 2008
    cant find scanner but can find printer on all in one fax and scan printer
  • Alleyk Apr 03, 2008
    I was able to print only a test page until I disabled the user controls under vista. I can now print but only SINGLE copies no matter how many copies I set it for.
  • GuitarDave Apr 05, 2008
    Vista Driver for Canon MultiPASS F50
  • Anonymous Apr 13, 2008
    need driver for vista
  • McKay Apr 14, 2008
    cannot use the hp laserjet printer P3005d with Vista Windows. Please assist me to download the driver
  • AARKAY Apr 15, 2008
    Not supported by Windows Vista Professional edition. Are there any drivers available allowing it to work on Vista?
  • busymom49 Apr 16, 2008
    Lexmark Z715 will not work with VISTA. I downloaded recommended drivers but still will not print.
  • Anonymous Apr 19, 2008
    The canner function inConon PIXMA160 does not compatible with windows vista
  • sanjaya4g Apr 20, 2008
    epson cx5400 printer does not work with vista. uploaded drivers from epson and windows site but still no printing. Goes though motions of printing but I only get blank pages.
  • Anonymous Apr 23, 2008
    I also have a Lexmark X1270 and run Windows Vista Home Edition - does anyone have any ideas how to get it to work ?
  • kathyk88 Apr 30, 2008
    Can get Canon iP4300 to print with toshiba computer that has vista.
  • Anonymous Apr 30, 2008
    NOT SUPPORTING WINDOWS VISTA
  • Anonymous May 04, 2008
  • Anonymous May 10, 2008
    no compatible con vista ultimate lite5 sp1
  • Tanzim May 13, 2008
    I am having Windows Vista Ultimate and unable to install Printer Driver for HP Laser Jet 3055 All in one Printer. Request your urgent assistance.
    Email : [email protected]
  • Anonymous May 15, 2008
    werkt niet
  • Anonymous May 17, 2008
    my prints are all blue
  • andres1 May 20, 2008
    Doesn't work with vista home premium
  • Sprinterfreak
    Sprinterfreak May 25, 2008
    Der Apple LaserWriter 12/640 PS wird von Windows Vista allgemein nicht unterstützt.
    Apple hat allerdings einen Treiber-Emulator für den HP LaserJet IIId integriert.
    Soweit sogut.
    Leider stellt auch HP keine Treiber für Vista bereit.
    Bleibt also wie in der Mehrzahl aller Probleme bisher nichts anderes übrig, als Vista wieder durch WIndows XP (für Spielkinder mit Vista-Style) zu ersetzen. Das läuft wenigstens.
  • Anonymous May 29, 2008
    bjc 80 is recognized but won't print or scan on Vista Ultimate
  • Guran Jun 05, 2008
    Canon Smartbase MPC 400 - Driver & software : Doesn't install at all on Vista, any version!
  • Anonymous Jun 10, 2008
    hp psc 2210 not compatible with windows vista
  • katietales Jun 19, 2008
    Not supported by windows vista. PLEASE HELP!
    HP Officejet 5110xi all-in-one is not supported by windows vista....PLEASE HELP!
  • Anonymous Jun 19, 2008
    hp photosmart c5180 photo printer not compatible with windows vista
    I have Windows Vista Business installed - 32-bit. I cannot find a driver for it anywhere. I find only 64-bit Vists drivers. Can anyone help?
  • Anonymous Jun 21, 2008
    printer driver not supported by windows vista for hp deskjet 1280 printer
  • Tipzl Jun 22, 2008
    The printer does't work on Vista
  • Anonymous Jun 25, 2008
    have a z45 lexmark and Vista HP.Down loaded the software for lexmark and it will not work the printer.
  • Anonymous Jul 02, 2008
    no driver fro vista ?
  • Anonymous Jul 11, 2008
    driver we install is for win xp not for vista but before one or two days it doing print properly.now it give error,why?
    I've just started to use Visra Home Edition. ML-1710P gives INTERNAL ERROR print when trying to print.
    Following error message is printed on paper:
    INTERNAL ERROR - FALSE
    POSITION:0x11fa4 (73636)
    SYSTEM:H6FWSIM/xl_tbl
    LINE:400
    VERSION:QPDL 1.17 08-25-2004
    Any help for this? I've loaded driver from Samsumg web-pages for Vista????
  • Lichtgestalt Jul 16, 2008
    Is there any possibility to find Vista HP compatible driver for Canon PIXMA ip1500?
  • joemawad Jul 16, 2008
    cannot find driver compatible with vista for mf inkjet 500
  • SazquatchWNC Jul 29, 2008
    I've been using this printer (KX-P7100) successfully for several years. I have recently purchased a computer running Vista Ultimate 64 and find that Panasonic has no plans for supporting a driver for Vista. While I recognize that obsolescence is a fact of life in the computer world, I would expect better of a world class corporation. I'll probably not buy another Panasonic product.
    SazquatchWNC
  • Anonymous Jul 30, 2008
    NO COMPATIBILY WITH VISTA
  • TIPOCARO Aug 05, 2008
    TENGO UNA CANON IR1370 PERO NO FUNCIONA CON WINDOWS VISTA POR EL ASUNTO DEL DRIVER. SERA QUE TIENE SOLUCION. GRACIAS
  • Anonymous Sep 02, 2008
  • donnalopez Sep 28, 2008
    i have a problem also to my hp deskjet 895cxi
    which could not be possibly installed on my
    windows vista laptop. anybody help
    me with my problem?
  • varna Sep 30, 2008
    HP 1315 all-in-one printer is not supported bu Windows Vista!!
  • Anonymous Oct 01, 2008
    !!!!!!!!!!!!!!!1111111
  • patsyskip1 Oct 13, 2008
    When trying to install my Canon PIXMA MP60, I receive an error message indicating that it is not compatible with Microsoft Windows Vista Home Premium. Can you solve this for me? Thanks!
  • Anonymous Dec 23, 2008
  • Anonymous Jan 09, 2009
    i can't add my lexmark 6200 printer on my windows vista
  • deborahlynnh Jan 09, 2009
    i can't install my lexmark 6200 printer to windows vista
HP DESKJET 1280PRINTER DRIVER
Posted on May 02, 2008
I need help installing my porinter to my windows vista comp
Posted on Sep 27, 2009
HP Officejet 5110xi all-in-one is not supported by windows vista....PLEASE HELP! ... are there any compatible drivers to print from vista platform? ...
Posted on Nov 27, 2008
Necesito el Driver de la Impresora Canon IP 1800
Posted on Aug 18, 2008
I used the Vista provided driver for the IP4000R.
Posted on Jul 26, 2008
KENTUT SEMUA PANTEK KAMU SEMUA PENIPU ANJING BABI
BELAU AND KUSUT SETAN DUNIA KIAMAT KAMU MATI DULUAN DEH ANJING BLAU
Posted on Jul 15, 2008
Nesesito el driver para mi impresora hp 1315 all-in-one por favor
Posted on Jun 25, 2008
Not supported with windows vista. I've tried everything I can think of....PLEASE HELP!
Posted on Jun 19, 2008
Not supported with windows vista. I've tried everything I can think of.....PLEASE HELP!
Hp deskjet 656c driver
Posted on Mar 03, 2008
Get drivers from
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&cc=us&dlc=&product=1128296&
Posted on Dec 17, 2007
I've successfully used the Xerox Docuprint 4517 driver.
Posted on Dec 15, 2007
Done it, but nothing
Posted on Nov 21, 2007
    Guru:
  • 1,463 Answers
Try the printer web site and see if you can get a download update for the software to run with vista.
riz.
Posted on Nov 02, 2007
3 Suggested Answers
SOURCE:
SOURCE: Driver for windows Vista home
Printer Panasonic KX-FLB802 Driver for this printer to work with windows vista home ultimate cannot be found. Does a driver exist to suite Vista and where can i find it. Many thanks
Posted on May 27, 2008
  • 331 Answers
SOURCE: the printer doesn't print
did u install the drivers for the windows vista version
try to download the Drivers for Vista from this site
http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us
Posted on Nov 02, 2008
I am trying to scan multiple documents and have them go into 1 file using Windows fax and scan with my HP3020 all in one printer scanner, this used to happen automatically when I was on XP but recently...
This is the latest version of HP's Universal Print Driver (UPD). The UPD, available in 32 and 64 bit packages, is a single driver that supports PCL5, PCL6, and HP PostScript; level 2 and 3 emulation.
Please review the Release Notes for information on issues resolved, performance improvements, and new behavior changes to the UPD.
Details and specifications File name: s.gif upd-5_1_1_8232-pcl5_win-xp-vista.exe [1/1, 14.6M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Client operating systems supported:
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
    *Note: Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the current UPD and tools for the discontinued Windows XP operating system until 2011
thumbs back!
Oct 28, 2010 | HP LaserJet 3020 All-In-One Printer
I have have downloaded the HP Laserjet 3015 Print driver on my Lenovo U330 Laptop with Windows 7 Ultimate. Unfortunatley, I've tried 2-3 times to with no success. Am I having a compatiblity issue with...
File name: s.gif upd-5_1_1_8232-pcl5_winxp-vista-x64.exe [1/1, 15.21M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Oct 25, 2010 | HP LaserJet 3015 All-In-One Printer
I cannot install ethernet driver of hp compaq d530. Where can i find it?
Hello: I hope the following information is helpful.
If you are trying to install the driver for the Broadcom ethernet NIC that was pre-installed (NOT an ethernet card that you purchased and installed yourself), there is a softpack (updated driver installation) download available from HP/Compaq. It will install the driver automatically for you, just download it from the link below and run the ".exe" file.
IMPORTANT: Check to be sure that your current Operating System, and model of the network device you are trying to install, are BOTH listed below BEFORE you download!
This is a software / driver update for the HP Compaq d530 ultra-slim desktop: All Models
Supported network devices:
BCM5906M Broadcom 10/100/1000 5782 based NIC Broadcom 570x 10/100 Integrated controller Broadcom NetXtreme Gigabit Ethernet 5782 Broadcom NetXtreme Gigabit Ethernet PCI-Express NetXtreme(tm) 10/100/1000 Gb NIC
Supported Operating Systems: Microsoft Windows 2000 Microsoft Windows 98 Microsoft Windows NT 4.0 Microsoft Windows Vista Business 32 Edition Microsoft Windows Vista Business 64 Edition Microsoft Windows Vista Enterprise 32 Edition Microsoft Windows Vista Enterprise 64 Edition Microsoft Windows Vista Home Basic 32 Edition Microsoft Windows Vista Home Basic 64 Edition Microsoft Windows Vista Home Premium 32 Edition Microsoft Windows Vista Home Premium 64 Edition Microsoft Windows Vista Starter 32 Edition Microsoft Windows Vista Ultimate 32 Edition Microsoft Windows Vista Ultimate 64 Edition Microsoft Windows XP Home Edition Microsoft Windows XP Professional Microsoft Windows XP Professional x64 EditionINSTALLATION INSTRUCTIONS: 1. Download the file by clicking the "Download" or "Obtain Software" button and saving the file to a folder on your hard drive (make a note of the folder where the downloaded file is saved). 2. Double-click the downloaded file and follow the on-screen instructions.LINK where file can be downloaded:HP/Compaq Support-Broadcom Driver download
Again, I hope this information is what you neededto install your network device. Should this not answer your question, please come back, provide more details of your problem, and we will be happy to help!Best of luck to you!
Jun 23, 2010 | HP Compaq d530 Ultra Slim PC Desktop
System requirements of vista
For Vista Home Basic >>>
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
For Vista Home Premium, Business and Ultimate >>>>>>
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
  • 800 MHz processor and 512 MB of system memory
  • Support for Super VGA graphics
  • CD-ROM drive
Regards.
Sep 21, 2009 | Microsoft Windows Vista Ultimate Edition
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
Cameramate driver for apple computer
Try to visit the link below to find yout cameramate driver that supports apple computer Operating system:
1. Cameramate Driver Apple Support Driver
2. Windows Support
Thanks
Aug 02, 2009 | Microsoft Windows Vista Home Premium...
Burner does not finalize discs
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.
APPLIES TO
  • Windows Vista Ultimate
  • Windows Vista Starter
  • Windows Vista Home Premium
  • Windows Vista Home Basic
  • Windows Vista Enterprise
  • Windows Vista Business 64-bit Edition
  • Windows Vista Ultimate 64-bit Edition
  • Windows Vista Home Premium 64-bit Edition
  • Windows Vista Home Basic 64-bit Edition
  • Windows Vista Enterprise 64-bit Edition
After you install Windows Vista on a computer that uses an SiI Parallel Advanced Technology Attachment (PATA) chip from Silicon Image, the computer does not recognize an attached optical drive as a drive that supports recording. Therefore, you cannot use the computer to burn CDs or DVDs.
This problem occurs because the SCSIport driver does not populate the correct number of bytes for an IOCTL_STORAGE_QUERY_PROPERTY Request Packet (IRP) when the device does not return a correct serial number.
Service pack information loadTOCNode(2, 'resolution'); To resolve this problem, obtain the latest service pack for Windows Vista or download the following Hotfix.
Microsoft Hotfix http://www.microsoft.com/downloads/details.aspx?FamilyId=2E692102-D483-44B0-BBFF-FA87AE019CBE&displaylang=en
Please rate this a fixya
Feb 01, 2009 | Microsoft Windows Media Player
Apr 09, 2008 | Panasonic KX-FLB801 All-In-One Laser...
HP Officejet 6310 All-In-One InkJet Printer Logo
2,231 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
