Question about Dell 924 All-in-One InkJet Printer
I'm trying to replace black color cartridge, but get an error message: carrier jam How do I unjam it? Already did the unplug- check for paper jam and replug...no luck!
    Novelist:
  • 177 Answers
Remove all paper...(inspect closely for paper jammed way inside!)
also remove both ink cartriges, reinsert them one at a time carefully and properly....also double check the number code on the ink
the jam error could be either paper or cartriges confusing the printer. let me know if it works....k
Posted on Apr 19, 2009
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Reads error #1200 when switched on, when the panel is raised up to check the cartridge it does not slide back and it does not print well at all. the brand is lexmark X4270 All-In-One inkJet printer. What i...
I noticed your message while searching for answers to repairing another Lexmark printer. You probably already have the answers by now but here is what the manual says.
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
The ultimate fix for this problem is to give your Lemark and Dell printers to people that you really dislike. Let them live with the frustration. Then buy yourself a Hewlett Packard, Canon, or Epson printer. Check the cost of the cartridges for each brand prior to making a purchase. Purchase the printer with the least expensive cartridges and one that will take the generic (compatible) cartridges available in retail stores and refill stores. My personal favorite are the Epsons. They print excellent colors and are very affordable to own, and most important, operate.
Jan 19, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do I fix the unsupported cardridge message
The error can be caused by either a communication failure between the cartridges and the printer, a dirty contacts on the cartridge or the cartridge carrier, or a defective cartridge. Try removing the cartridges from the printer. Close the cover. Wipe the nozzles on the cartridges with a damp paper towel. Unplug the printer from the power source. Wait at least 30 seconds before replugging. When the printer's ready, reload the black cartridge then close the cover. If error displays, replace the black cartridge. If no error, reload the color cartridge. If error displays, replace the color cartridge. If you have already tried replacing both cartridges with new ones yet error displays, I strongly suggest you contact Lexmark technical support to further investigate the problem. Thanks.
Aug 20, 2010 | Lexmark X2350 All-In-One InkJet Printer
Error 2200
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off the AIO and remove the power supply from the back of the unit.
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Feb 06, 2010 | Lexmark P6350 All-In-One InkJet Printer
Dell 944 error message 1102 after fitting new DellBlack Cartridge
hi there,
you can try these steps:
try to remove the new black cartridge. get a clean cloth. gently wipe the copper strip of the cartridge. unplug the power cable of the printer. gently wipe the contacts of the black cartridge carrier (where you put the black cartridge in). close the carrier, plug the power cable back in. install the black cartridge. then check for the error code.
if you still have same error code, try the old cartridge.
if the old cartridge still works, you need to contact dell for the replacement of the black cartridge (if you purchase the black cartridge from dell)
if the old cartridge is also giving same error. try the steps on the color cartridge as well, it might be with the color cartridge error.
or both.
worst case scenario the contacts on the printer carrier might be broken already.
but in this kind of situation. 98% it's the cartridge that's causing the issue.
have a great day :)
Oct 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Dell 924 All-in-One InkJet Printer Logo
104 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
