Question about Intel Motherboard
SNAPPED STUD TO THE WATERPUMP
I HAVE AN 89LINCON I WAS TAKING THE WATERPUMP OFF AND SNAPPED THE LONG STUD THAT I THINK GOES TO THE HEAD IT IS ONE OF THE STUDS THAT IS THREADED ON BOTH SIDES
Hold a nut against the broke bolt and weld inside it. That will heat it up as well as making a new head.
Posted on Oct 05, 2007
AN 89LINCON is this a car? if it is you can use a screw out from sears.
Posted on Sep 26, 2007
    Sergeant:
    Champion:
  • 293 Answers
Is it copper or plastic tubing? Just replace that part.
Posted on Sep 20, 2007
SOURCE:
Mini digger over heating
several possible problems
1 if the stud holes were not cleaned out with a thread tap and compressed air then you will be bottoming out the studs at the head tension settings but not compressing the head onto the head gasket correctly
2 head is warped/ cracked and needs shaving and crack detecting
3 cracked cylinder wall/s
4 blocked radiator fins and cores
Aug 27, 2016 | Mini Cars & Trucks
I have a 2001 wide glide, and one of my exhaust studs snapped off below the surface on the front cylinder head. Does anyone know if I can extract it with the head still on the motor or do I need to pull...
Hi David, you should be able to extract the broken stud piece with the head on the engine. you will need a screw extraction kit snap on makes the best one but any place that sells tools, ie sears or harbor freight ect. will have some type of kit. it requires also a drill bit, and be aware that the straighter and dead center the hole will maxamise your final result. also the drill bit must be new or extremely sharp to keep the bit from walking also use a center punch to dead center the stud giving the the drill a primo place to start drilling. Now if you fail with this method dont feel bad it happens alot even to the most experienced tech. There is a second option buy a 5/16-18 helicoil kit and follow the instructions its fairly easy again drilling the hole accurately will give you the best results. good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 23, 2015 | Harley Davidson Motorcycles
My RGDG-100AUER will keep a pilot flame for one burn cycle. When what I think is the beginning of the next burn, I hear a click, and the flame goes out. If I hold the pilot stud down, relight it, the...
Check the flame sensor is clean . or pilot may be blocked .Too short and the main gas is taking the flame away so it goes out , Also check thermocouple .
Oct 10, 2017 | Heating & Cooling
I have a craftsman chainsaw that I have snapped off 1 of the studs that hold the chain bar no.Problem is I cant work out how to remove the snapped stud. Are they screwed in or pressed in? how do I get them...
Go to: www.Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of replacement part drawings. Check the drawing for the stud and see if it has a square head which would imply that it is replaceable from behind the bar bracket. Hope this helps!
Jun 18, 2010 | Garden
Stud snapped off when taking the front left tire off. What is the part called with the threads on it?
that is called a wheel stud you can pick up one at your local advance auto and they also have the oem type lug nut to fit your truck also
Jan 18, 2010 | 1996 Chevrolet S-10 Pickup
I have a 97 scrambler 400 4x4 i stripped some of the jug studs out of the jug when i went to tighten the head down how can i fix this problem w/out taking out the jug? I am also not getting any power to...
hi buddy maybe a blown fuse on the head light or blown bulb also the only thing i can think off is you taking the studs out by putting 2 nuts on the thread and tighten them together then on the bottom nut turn it anti clockwise and the hole stud will come out then pop to your local hardeware store and get some studded bar and then cut to the length required thats it buddy
Dec 04, 2009 | 1983 Yamaha XS 400 L Maxim
2005 Ford Taurus SE power steering pump
I just did it on a 99 sable w/ dual overhead cam.... You need to pull the pulley off first and expose three 10mm mounting bolts. I had a heck of a time getting the return line loose. I think it was a 18mm line wrench,
TR
Sep 17, 2008 | 1999 Ford Taurus
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
